Spark plugs & ingnition coils
Old Apr 18, 2008 | 01:46 PM
seagram14's Avatar
When should you change the spark plugs and the ignition coils? And how many ingnition coil are there?
Old Apr 18, 2008 | 02:32 PM
nsnell19's Avatar
I drive really fast
There are 4 ignition coils. 2 for each rotor.
Old Apr 18, 2008 | 02:34 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Oh boy!
Old Apr 18, 2008 | 03:44 PM
Jax_RX8's Avatar
Got Another Rotary
I plan to change both at 30k - barring any issues before that.
Plugs could need changed every 15k if you do not run enough cleaners and are seeing misfires. Also, coils could be sooner if you live in a hot climate as they are notorious for overheating/scorching, but also have been stretched to 60k and beyond by some with no issues either.
Bottom line is keeping in touch with how your Renesis is running and adjust changing these out accordingly.
Don't forget your plug wires either - good idea to swap them out at least every 60k as well (if not sooner)
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
TeslaMSI
Dec 10, 2015 01:10 AM
iwannarun
Sep 6, 2015 01:37 PM
