Where to get a Switchblade Key Cut Besides the Dealer?
Old Apr 18, 2008 | 09:21 AM
Nopstnz8's Avatar
Question Where to get a Switchblade Key Cut Besides the Dealer?
Hey guys I just got a switchblade key and I need it cut. I don't want to have to go to the dealer if possible, because the closest one is at least 20 minutes away. Is there anywhere else I could go to get it cut and not have to worry about the key getting messed up? Thanks.
Old Apr 18, 2008 | 05:51 PM
kersh4w's Avatar
Hit & Run Magnet
any local hardware store will cut the key for you.
search the forums for the programming method, to program the rest of the key to the car.
Old Apr 18, 2008 | 06:00 PM
r0tor's Avatar
i was also thinking harware store... not sure if they will do it or not though
Old Apr 18, 2008 | 09:28 PM
G-ReX's Avatar
A Torque-Free Zone
If the hardware store messes it up, you're SOL. My dealer miscut mine the first time and replaced the it.
Old Apr 21, 2008 | 05:28 PM
r0tor's Avatar
my dealer seems to have muffed mine up as it works in the ignition but not the trunk or doors... and they refused to give me a new one since I didn't buy the key there (couldn't lie since he was looking me up in the computer...)
Old Apr 21, 2008 | 05:55 PM
HighRev'n's Avatar
I took mine to a neighborhood hardware store that actually cuts the keys themsevles not like Lowes or Home Depot where they have an automated machine do it. This being a non standard key it won't fit into their auto machines. Also to rOtor you should try to match up your original key to the one cut. I also had the same problem intially then I saw that one of the spots was not cut enough. Once that spot was fixed it works in all locks now.
Old Apr 21, 2008 | 07:12 PM
G-ReX's Avatar
A Torque-Free Zone
I guess it depends on the dealer. My key was off eBay, but they still replaced the miscut key. They also don't charge to cut keys. Kudos for Hall Mazda.
Old Apr 22, 2008 | 12:29 PM
r0tor's Avatar
well, my dealer didn't charge anything to screw it up at least
Old Apr 22, 2008 | 05:26 PM
r0tor's Avatar
after an hour spent with a file and set of calipers, the 10 thousandths of an inch at 2 spots that was preventing me from using the key have been removed...
it works finally
Old Apr 22, 2008 | 05:41 PM
Nopstnz8's Avatar
My dad took the key to Fremont Mazda today to get it cut and the idiot tech guys tells him that the key won't work on an '04, after he already told the guy it has been proven that it works on an '04. He also said that the key could cause the computer system to go out. He says it will cost 125 to program, but I want to do it , myself because I have 2 working keys. Is this guy full of **** or what? Should I just try another Mazda dealer in the area, or somewhere else? I am very eager to get this thing cut so I can program it.
Old Apr 22, 2008 | 07:53 PM
G-ReX's Avatar
A Torque-Free Zone
I programmed the remote fob first. That way there was no question. After hearing everyone's issues, I think I owe my dealer some Krispy Kremes.
Old Apr 23, 2008 | 02:15 AM
Nopstnz8's Avatar
Did you program it or did the dealer do that? If you did it yourself, how did you do it without cutting the key since it needs to be inserted into the ignition to be programmed.
Old Apr 23, 2008 | 06:38 AM
r0tor's Avatar
get the key cut then program the key and remote yourself... its not difficult at all really
Old Apr 23, 2008 | 10:17 AM
Nopstnz8's Avatar
That is what I plan to do once I finally can get it cut.
Old Apr 23, 2008 | 08:39 PM
G-ReX's Avatar
A Torque-Free Zone
I programmed the remote portion first. I actually used the remote for a day with the uncut key, just to make sure it would work before I had the key cut.
cliffkemp
Dec 24, 2024 10:48 AM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
RAVSPEC
Vendor Classifieds
Oct 1, 2015 01:59 PM
D13
Oct 1, 2015 07:55 AM
FubarI33t
Sep 28, 2015 08:45 PM
