FS: NIB Mazsport Cooling Mod
Bought brand new a few months ago. Never opened the plastic bag it came in.
Brand new in box with instructions.. Paid around $140 with shipping.
Sell For $100 Shipped Priority Mail
• Mazsport Cooling Fan Control Kit
• 2 Hose Clamps
• 6 Wire Ties
• Comes ceramic coated for long lasting good looks!
• Extended engine life - lower engine temperatures extend engine coolant seal life.
• Improved air conditioning efficiency - lowering air conditioning condenser temperatures makes a difference you'll appreciate on hot days.
• Better engine compression - the operating temperatures of a rotary engine will have a direct effect on engine compression. The lower the operating temperatures, the higher the engine
compression.
• Better hot starts after short-term parking.
• More consistent idle due to higher compression and lower heat soak levels.
• Better low RPM throttle response and horsepower due to
higher engine compression.
• A cooler engine = a happy engine!
SEE DYNO RESULTS
• Works with all RX-8’s from stock to highly modified forced induction applications.
• No monitoring or switching required, performs all the work for you.
• In many cases eliminates the need to upgrade more expensive
cooling system components by simply improving the efficiency of the factory components.
• Fans operate normally when temperatures are not excessive and only cycle more frequently when needed.
• 2 Hose Clamps
• 6 Wire Ties
compression.
SEE DYNO RESULTS
