HELP: Mazda Engine cleaner application done---> now problems!
Old Apr 17, 2008 | 10:16 AM
HERO's Avatar
Exclamation HELP: Mazda Engine cleaner application done---> now problems!
So I bought the mazda zoom power engine cleaner and did the job last night as per nycgps's diy instructions. I go to start the car today, and do the warm up/rev work. Now I have the check engine light on and there is a distinct and loud ticking/whistling sound coming from the engine (It was there ever since I first started the car up after the treatment). It increases and decreases in volume and goes up and down in pitch as the motor revs. Any ideas whats going on??
Sam
Old Apr 17, 2008 | 10:21 AM
Sam
Car spec, mileage, Mt/at, etc oh make sure everything Is *BACK TO THE WAY IT WAS* this is very important !
start the car today? u left the cleaner overnight or ?
did u check and see what CEL is ?
Celronx's Avatar
Unregistered User
Did you make sure that all the nipples and lines are all reinstalled and not leaking? Sounds like an intake leak to me.
Old Apr 17, 2008 | 10:46 AM
HERO's Avatar
04' MT w/ 42k miles.
The only things disconnected were the two connectors on the pass side of the engine bay and the one at the bottom by the big pulley. All 3 are snapped back together and in place. Also, the rubber things that close off the 2 nipples where the cleaner was injected are both in place.
I left the cleaner overnight.......
Old Apr 17, 2008 | 10:48 AM
Find out what the CELs are.
maybe ur CAT or plugs.
Old Apr 17, 2008 | 10:51 AM
StealthTL's Avatar
Metatron
Check your nipples!!
S
Old Apr 17, 2008 | 11:11 AM
Jax_RX8's Avatar
Got Another Rotary
S
I bet you've been waiting years to say that
Old Apr 17, 2008 | 11:41 AM
ROFL !
Old Apr 17, 2008 | 02:39 PM
Nubo's Avatar
Lubricious
Is engine running smoothly otherwise?
Check to make sure you don't have a loose spark plug.
Old Apr 17, 2008 | 03:22 PM
Go48's Avatar
Clear the CEL by disconnecting the battery for a few minutes. That happened to me the last time I disconnected and then reconnected the Eccentric Shaft Position Sensor (which I assume is one of the connectors you refer to).
Old Apr 19, 2008 | 10:07 PM
HERO's Avatar
All is well now! The sound just disappeared the next time I started her up. The cels were 0480 and 0481 which are about the cooling fan. Ive had these on before due to my mazsport cooling fan nod. Guess it was just a weird coincidence that it came on right after I did the cleaning.
Thanks for all the quick help though guys!! Much appreciated!!
Old Apr 20, 2008 | 06:23 PM
XRX8X's Avatar
more then a Mazda
who's the hero now?is it good to know these guys or what?thanks and hats off to all who help the little blunder we all do every now and then!
Old Apr 20, 2008 | 07:06 PM
me me ?????
Old Apr 21, 2008 | 02:02 AM
Don't try to be a Hero ...
Old Apr 21, 2008 | 02:09 AM
Spinning Sushi's Avatar
I <3 Sushi
Attached Thumbnails HELP:  Mazda Engine cleaner application done---&gt;  now problems!-120407775456.jpg
Old Apr 21, 2008 | 07:21 AM
My name ....
Is NEO ...
Old Apr 21, 2008 | 09:59 AM
dillsrotary's Avatar
jersey fresh
How's the car running besides the cel?
Old Apr 21, 2008 | 12:14 PM
Nubo's Avatar
Lubricious
Interesting. I wonder what caused clicking and whistling, then went away? Some chunk of carbon that got dislodged then stuck again? Stuck in intake port? Well, better out than in, I always say
Old Apr 21, 2008 | 12:22 PM
I observed the weird ticking sound on both cars that I did this to yesterday. As I mentioned in the DIY thread, only 1 car threw a CEL.
Both had a different sound to them for a few minutes but returned to normal.
Glad you're fixed.
Old Apr 21, 2008 | 02:28 PM
be aware that youare essentially washing all the lubricant from the rotor housing surfaces and seals, although there is some light lubricant in most of these types of cleaners
technicians with the Mazda service equipment are directed to initiate an increased MOP sequence following the cleaning procedure
if you intend to do it yourself you may want to consider adding oil back onto the surfaces similar to performing a compression test prior to actually firing it up, my 2 cents
Old Apr 21, 2008 | 03:26 PM
Or Premix :o
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
Sifu
Aug 30, 2015 10:51 PM
Kim Jong Illest
Canada Forum
Jul 23, 2015 03:22 PM
Belalnabi
Jul 17, 2015 07:48 PM
