View Full Version : Is my car special or did they get it right?
I bought my 8 in Oct. It had a August build.
So far I have.....
not flooded the engine.
I get 22 mpg with 60% highway
Center console does not get hot.
oil is just below full with 1700 miles.
Air does not cycle on and off.
no CEL.
In fact, no problems at all.
So WTF?
useless sarcastic comment deleted;)
Winning_BlueRX8 11-10-2003, 09:10 PM i've got 4000 miles on mine and zero problems, but i can't boast your 22 mpg...i get about 18-20, depending on how much highway I drive. in other news I had my spoiler installed today, and they treated me to a loaner red rx-8 and a tank of gas while it was being installed =) Loaner cars are so fun.
8_wannabe 11-10-2003, 09:15 PM You forgot to mention... do you get the low oil light? But yes, I'd say you got lucky.
Here's my tale:
Not flooded the engine.
I get 16.8 mpg with 60% highway
Center console gets hot.
Don't seem to burn much oil.
A/C cycles on and off.
No CEL.
No low oil light.
So who's the poor shmuck that gets ALL these problems? Someone who should have taken his car back.
Superfan 11-10-2003, 09:18 PM What are your shift points? Do you go WOT often? Have you dynoed the car, you might even have the 250hp fuel maps. After you go for a drive (with the center console lid closed) open it up and check for heat. Are you sure about the A/C not cycling on and off? The A/C and Heat problem were reported back in April by a few of the RX-8 owners in Japan. So it isn't a US specific issue.
8_wannabe 11-10-2003, 09:29 PM Originally posted by Superfan
What are your shift points? Do you go WOT often? Have you dynoed the car, you might even have the 250hp fuel maps. After you go for a drive (with the center console lid closed) open it up and check for heat. Are you sure about the A/C not cycling on and off? The A/C and Heat problem are were reported back in April by a few of the RX-8 owners in Japan. So it isn't a US specific issue.
Dude, be happy for the man. At least for one guy everything is working right. Mazda oughta buy his car back from him for like $1,000,000 and dissect it to figure out why everything works. ;-)
mngpao 11-10-2003, 09:38 PM I got my Winning Blue AT in August. It just turned 2k miles. I drive about 80% hiway and have been getting 22-24+mpg.
Oil is down about 1/3 quart - I started checking it at about 1k miles after reading about others having an oil problem so I don't know if it started out that low or it burned it.
Other than that, I've had none of the problems others have been talking about. When I take it in for its first service, I'll inquire about the oil pan with baffles and some of the other "fixes" that should be in the dealer's list of TSBs.
P00Man 11-10-2003, 09:49 PM i have no problems, get 20+mpg, i think my ac MIGHT cycle, but ive nevered noticed it, i dont notice any strange warm areas, 2700 miles, oil consumption is not so much
so far my car is right on, and a pleasure to own and drive
________
EXTREME VAPORIZER (http://extremevaporizer.net/)
XUrotaryrocket 11-10-2003, 09:57 PM there's only a few people on here with problems. every car model has a few duds..... it's normal.
don't listen to the people who bitch and moan over nitpicky sh#t.
this is a GREAT CAR !!!!
Gord96BRG 11-10-2003, 10:15 PM Originally posted by mngpao
It's not a problem - the engine has oil injectors to inject oil into the combustion chambers; it's supposed to burn a little oil. That's why you're supposed to check the oil level more often, and add as required!
Regards,
Gordon
khoney 11-10-2003, 11:44 PM No problems here. The A/C does cycle (cold/cool), but I'm assuming that's by design. 20MPG mileage. 230HP at the wheels.
OK, just kidding on that last item :D
AvitalBlue8 11-11-2003, 02:05 AM Havn't flooded engine
No CEL's
2 Low Oil lights (but getting oil pan replaced on friday)
Has used 1 quart of oil at 2500 miles (did oil change @ about 1k miles)
AC doesn't cycle
13-15 MPG, 80% of driving i'm shifting at 8k-9k, lots of WOT, other 20% i'm stuck in traffic.
Center console doesn't get hot
But the passenger side door panel is sqeaking when i go over bumps or when i play music with a good amout of bass.
All in all i'm pretty happy.
mikeb 11-11-2003, 02:54 AM Ive got 6500 miles
no flooding
no oil lights
two cel lights
19 mpg
shift_zoom8 11-11-2003, 04:53 AM Originally posted by mngpao
Something is definitely wrong with your car. I'm especially concerned about your mileage. You may need to file a complaint or inquire about the buyback.:cool:
vibec 11-11-2003, 06:13 AM well i have 1600miles
no flooding
15mpg - only 30% highway and always in traffic- that's ok, i tend to drive aggressively (otherwise why buy the car?)
aircond ok at 38 degrees celcius
centre console heats the ENTIRE cabin once you stop the car and leave it there for a bit (even when parked undercover)
no oil pan light
no squeaks
so I consider myself pretty lucky, less so when its 38 degrees celcius and Im sweating like a pig getting back into my parked car.
DMCHRISTIE 11-11-2003, 07:48 AM I have 2300 miles
added 1/2 qt of oil
16-20 mpg
a/c cycles
built 06/03
tire light has come on twice both times all 4 tires were 4 lbs short (its getting colder in NC)
drivers side rx 8 kick panel came unglued
no other issues
Drive it like you stole it!
Jhouse 11-11-2003, 10:11 AM havent noticed any problems
1800 miles
has new wheels,sensors work great although they still suck
bought it a month ago
don't know when it was built
redline it atleast once every time i drive it....ok maybe more than once.
It's yellow and everytime i go to a coffee shop everybody inside is talking about it when i get in there as i just eagerly await my mocha.
oh yea its a sport package.
I have had zero issues with my car as well... I am hoping that the fuel economy gets better, but I am only at 1,000 or so miles, so it should get better.
VelocityRedRX8 11-11-2003, 11:20 AM Let's see:
2100 miles,
Used 1qt of oil
No CEL
No Oil light
No A/C cycling
No hot center console
No squeaks
A few brrrrps around 3000 rpm (both times cold engine)
13-16mpg with around city driving
18-23mpg on highway
All in all I'm very pleased, but would like a bit more torque.
Senseny 11-11-2003, 11:57 AM I have 1700 miles on my blue 8. Fuel consumption seems to be getting better. The tire pressure warning light came on once and the tires were slightly low (3-4 lbs). There has been some oil consumption, but that is by design. So far so good, I love the car. Yeah, just like everyone else I would love more torque especially on the low end, but I knew that this was the case when I preordered the car. The great points outweigh any negatives by far.
ScottySilver8 11-11-2003, 12:29 PM 2200 miles
No CEL
No flooding
No Oil light
No hot areas including console
No squeaks
Not sure about AC cycling - don't think so but haven't specifically checked
~16mpg driving aggressively
Compliments, thumbs-up and/or lustful looks almost daily
Couldn't be happier!!!
texian 11-11-2003, 01:16 PM Originally posted by matt
So far I have.....
no CEL.
So WTF?
Ditto, but mine has >7K miles on it. Not even a whiff of trouble.
mikeb 11-11-2003, 01:57 PM Oh I forgot
countless smiles on my face while driving
and around 2 to 3 compliments daily from others
To all the "No engine flooding"respondants: Was this because you have avoided the situation that tends to cause it, or have any of you actually tried the cold start, switch off, restart?
I think I can learn to live with this, but the accidental stall pulling out of the garage in the morning has me a little concerned, particularly when the wife will drive, as she has not driven a lot of stick. (Of course, having said that, you all know who will actually be the one to do this........)
mikeb 11-11-2003, 03:26 PM no floods
but I have not cold shut off
I drive it like any other car without paying extra attention. I will cold start it and back it up 6 feet to wash it and start it up again to move it back in. It starts on the 1st try all the time.
8_wannabe 11-11-2003, 03:33 PM Originally posted by 7up
Well, it's not like I'd break the rules just to see if I can make it stall. That'd suck. I try to follow 2 simple rules: (1) Warm up for 10 seconds before putting into gear. I spend the time buckling up, getting the right music on, etc. so I'm not just sitting there. (2) Let the engine run at least 2 minutes before shutting down. If I'm backing out to wash the car, I'll take it around the block then pull into the driveway.
I've had no hint of a stall or flood yet, but I have no idea if the car gives you any kind of warning signs when you're running close to disaster. If so, I've had none.
Elara 11-11-2003, 04:43 PM No A/C cycling
No creaks
14.9-23 mpg, depending on whether I'm city/highway
Used about a quart and a half of oil in 4800 miles
No CEL
Tire pressure light for 5 minutes yesterday when it was cold
No engine flooding
I've only really had the oil light issue, and I'm asking the dealer about that this week when it goes in for the 5,000 mile check-up. Probably won't be fixed before my long trip to Niagara, but as long as we keep the oil full it doesn't come on. I've also cold-started and turned it off a few times, when i wasn't thinking, and it's started back up every time. But I have a feeling I've been lucky in that, so I'm not going to push it if I can help it.
KKMmaniac 11-11-2003, 04:46 PM So far, my car has been trouble-free. I'm using a bit more oil than I was lead to believe I'd be using, (~ 1 qt. per 2300 mi.) but I know this varies with driving habits.
I hate to say it, but even though things are great with my car, after reading about the few bad experiences some have had on this forum, I feel like my car is gonna suddenly vaporize or something. Oh well, it's just my paranoid nature.
WayneOsWorld 11-11-2003, 11:09 PM I bought my 8 in Sept. It had a July build.
So far I have.....
not flooded the engine. :)
(Although I learned my lesson with my 7)
I get 17 mpg with 10% highway. :|
Center console does not get hot. :)
Oil use is <1 qt at 1000 miles. :)
Air does not cycle on and off. :)
No CEL. :)
Coolent leak from bad seal that resulted in a new engine. :(
In fact, 1 problem - now solved. :)
Lots and lots of positive looks and comments. :)
So WTF? A very minor engineering mistake (although very expensive for Mazda), resolved without questions.
I love my 8!
khoney 11-12-2003, 09:13 PM Originally posted by WayneOsWorld
So far I have.....
No CEL. :)
I love my 8!
I love your attitude, WayneO!
pyrospawn 11-12-2003, 11:05 PM no flooding, althought i cold started and restarted a few times.
center consoles does not get hot
oil use is minimal
air does cycle on and off but very rare
no CEL
no oil light
no tire pressure light
Milleage increase from 16 to 23 mpg after first oil change at 3k miles.
It drops back to 17 mpg after that big temperature drop in MD.
so far at 7200 miles, in 2.5 months, it has not give me any trouble (knock on wood)
I am a happy 8 owner.
Jaycee 11-12-2003, 11:18 PM This is such a great car! My experience:
No flooding - and every morning I cold start it, back it out of the garage, then turn it off for a couple of minutes before restarting.
I had the oil warning light issue and Mazda replaced the oil pan - the problem hasn't recurred.
No problems with air con
no CEL
I say again - this is a great car !
ZoomZoom 11-13-2003, 03:32 PM I've had my 8 since August 28th and I now have about 11,000 km of carefree driving including free oil and filter. :D :D :D
I do wish fuel economy was better - but what the hell.
mmmdowning 11-13-2003, 09:49 PM Bought mine in Oct. I've put 3000 miles on it. 100 miles a day round trip to work.
No floods.
No heat.
Eats very little oil.
Don't know about AC, I fly with roof open.
MPG-With this car you never look at mileage. Wasn't bought to be a HYBRID.
Love the car, wouldn't trade it for anything. Even choose it over the Z6 Vette.
