Grounding kit: a couple of ways to do it...
Old Apr 14, 2008 | 11:22 PM
poweredbyplaav's Avatar
im interested in getting a grounding kit for the car, but i noticed that there are a couple of ways of doing it:
-one way is to run a wire from the negative terminal to your first part, then from that part to the next. z enterprise is an example of this http://maxground.com/mazda.htm
-another way is to run a wire from the negative terminal of the battery to all the parts that you plan to ground, meaning all grounding wires originate from the negative terminal. an example of this is the HKS grounding kit https://www.rx8club.com/showpost.php...92&postcount=4
I would think that the HKS style of doing this would probably be the optimal way, but many are doing it the z-enterprise way. Any suggestions?
Old Apr 14, 2008 | 11:49 PM
zzz ssssssssss snake oil
Old Apr 15, 2008 | 01:07 AM
are you referring to the one from z-enterprises or grounding kits in general?
Old Apr 15, 2008 | 03:07 AM
Wind Dance's Avatar
Central Valley RX8
All kits would be near equal if even noticeable. You can get Lineage grouding kit for about $100. Just don't expect much because mostly is just brand name.
My 2cents
Old Apr 15, 2008 | 03:21 PM
k thanks
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
stickmantijuana
Sep 4, 2015 10:31 PM
