Ticking noise high load above 5K Revs
Old Apr 13, 2008 | 03:13 PM
kristopher_d's Avatar
Drive Master
Starting yesterday evening I've been getting an odd ticking noise at roughly 3/4 + throttle with rev's above 5K. I've had the experience of pinging while running cheap gas going over the pass. This noise is different. It sounds more mechanical.
I did change the oil yesterday, and have checked for leaks at the filter and elsewhere. There don't seem to be any, and there's plenty of oil in the engine (yes, I did check).
Old Apr 13, 2008 | 03:14 PM
Maybe your heat shield is loose at the cat.
Old Apr 13, 2008 | 07:06 PM
Drive Master
Not the heat shield, but thanks. While I was under the car I noticed one of the plug boots was loose. I reseated them all, and now the sound definitely the pffft of a misfire. It's also not happening as readily. No CEL, but that's neither here nor there. Next step is testing the coils.
Old Apr 14, 2008 | 05:46 AM
Speedsteve's Avatar
Speedsteve
Hi
Does it go away when you turn off your airco ?
If there is not enough gas on the airco circuit, the pump makes a loud metalic clicking sound...
Steve
Old Apr 14, 2008 | 11:12 AM
Drive Master
A/C wasn't on, fan set to 0, vents to face only.
It's not steady, and after reseating the plug wires the sound isn't as harsh and mechanical. It's now the soft puff and momentary hesitation of a misfire. Still no CEL though, which I had received when she misfired at the track.
Old Apr 15, 2008 | 11:10 AM
Drive Master
More data. Plugged in my AP and watching the AFRs. Seems, when she spits, she's going lean, but it's still definitely not a distinct "ping." Quite a bit of troubleshooting to do, I think.
Old Apr 16, 2008 | 06:45 PM
shaunv74's Avatar
Power!!
Was it with the stock map or the AP map that you started hearing it?
Could still be coils or crap gas. Injectors clogged maybe?
Old Apr 17, 2008 | 10:25 AM
olddragger's Avatar
do the pedal dance and see if that affects it.
OD
Old Apr 17, 2008 | 11:26 AM
Drive Master
Stock map. Showed up about 14 hours before I got my AP.
What is the "pedal dance?"
RevMeHarder
Jun 1, 2026 02:30 PM
OnebaddRx8
Aug 25, 2019 11:34 PM
WranglerFan
Nov 5, 2017 09:35 AM
Jb4ker96
Sep 27, 2015 10:06 PM
Hiroshima_RX
Sep 21, 2015 06:28 PM
