Rich mixture (Richer than normal) in stock RX-8 !
Old Apr 13, 2008 | 10:32 AM
rotaryPilot's Avatar
Lately I have witnessed several stock RX-8 (when I mean stock they may have a free flow filter element at most) that they appear to have rich mixture specifically at top end. I know that all renesis are using rich mixture however this mixture seemed to be richer than normal. This was identified with the help of wide band sensor.
So what do you think is the cause for such a situation? I can personally think of a problem that has to do either with the MAF or the CAT. I do not think so that the free flow filter is responsible for the rich mixture.
What do you think?
Old Apr 13, 2008 | 11:00 AM
Old Rotor's Avatar
Mazda set it that way to meet emissions. Have you changed your air filter?
Old Apr 13, 2008 | 11:43 AM
CyberPitz's Avatar
Huge hole is huge
If you lean it out, wouldn't you, probably, lose emissions and gain a couple HP?
Old Apr 13, 2008 | 12:30 PM
Well I mean that the stock RX-8s that I have seen with the rich mixture are richer than other stock RX-8s.
Old Apr 13, 2008 | 12:36 PM
MazsportScott's Avatar
Mazsport.net
Check the coils, weak spark=rich mixture.
Old Apr 14, 2008 | 02:01 AM
As I recall the car has new coils and plugs ! Could it be the spark plug wires? Or is it possible that a free flow element to induce a richer mixture because MAF will see the extra air?
Old Jun 19, 2008 | 03:49 AM
Hi again,
I have noticed that after an ECU reset the car performs better special in high RPMs and in 4th, 5th gear. I have checked this after drag racing several times with stock RX-8. But let me explain you better what I mean.
My car has a Revi + Ram Air and at a drag race with stock RX-8 it seams that the stock RX-8 has a small advantage when at 4th gear. However, when I reset the ECU and I drag race again my car performs better and the advantage of stock RX-8 disappears.
Is it because after the ECU reset I run lean and this helps me at high speeds , high gears?
Old Jun 19, 2008 | 02:24 PM
kersh4w's Avatar
Hit & Run Magnet
i thought it was common knowledge that rx8s ran pretty rich...
Old Jun 19, 2008 | 08:10 PM
jones75254's Avatar
^^Yup, rich bitches. Get a flash tool to get those AFR's to mid/upper 12's. Put that bitch on a diet!
Old Jun 19, 2008 | 11:12 PM
Only way to fix the rich condition is to buy the Access Port from Mazda Maniac
Old Jun 19, 2008 | 11:24 PM
fahrfegneugen's Avatar
Explains a lot of the cat problems
Old Jun 20, 2008 | 01:25 PM
Ok , My question is that after an ECU reset are you running leaner for a while and as you put some miles you are getting richer and finally you remain richer???
Is this statement correct?
Old Jun 20, 2008 | 02:22 PM
mmats69's Avatar
93.5 octane
possibly. after a reset the car is trying to "re-learn" how you drive. that may have something to do with it.
uZu
Dec 30, 2015 12:35 PM
9krpmrx8
Nov 5, 2015 11:45 PM
Stubbs
Jul 28, 2015 09:23 PM
vssystemluba
Jul 19, 2015 04:16 PM
