Low-oil indicator while rev engine
Old Apr 12, 2008 | 01:29 AM
User24's Avatar
I'm driving back from MSP16, and on the freeway I rev from 7 to 8.5 in neutral anywhere from 20 to 50 times in rapid succession. Back in gear, 500 ft later I have a flashing yellow oil indicator that stays for about one minute.
I checked the oil at full shortly after. Can someone help me understand how the engine runs out of oil, with a full oil complement?
Old Apr 12, 2008 | 01:37 AM
cks796's Avatar
Computer Nerd
Maybe it's because you're burning all your oil. Also, reving the engine to 7 to 8.5 RPM's in rapid sucession 20 to 50 times is really NOT good for the motor. Espically that many times.
~CK
Old Apr 12, 2008 | 02:20 AM
Flashwing's Avatar
3-wheeler
Wait flashing yellow? The oil indicator to my knowledge is a red light. The only flashing yellow light would be your check engine light. Flashing usually indicates a misfire.
Reving the motor to the higher RPM band isn't going to cause any issues, if anything it's going to help blow the carbon out. Double check but I've never seen a yellow oil light. Please correct me if I'm totally mistaken on this.
Old Apr 12, 2008 | 03:06 AM
User24's Avatar
Oh, I see. I assumed it was oil since it appeared underneath the oil temperature gauge section. After checking the manual I realize that any number of symbols may appear in that window.
Old Apr 12, 2008 | 01:50 PM
kersh4w's Avatar
Hit & Run Magnet
you kept revving your motor after getting a CEL?
20 to 50 times?
are you nuts?
ladnarf1
Apr 29, 2021 11:53 PM
vapor2
Nov 3, 2020 03:38 PM
dbarber
Jul 25, 2015 01:34 PM
Belalnabi
Jul 17, 2015 07:48 PM
