Are double sided tape necessary for fender strakes
Old Apr 12, 2008 | 01:20 AM
fatmanyee's Avatar
I am about to put on some strakes, but these ones didn't come with the double sided tape. Will it still be ok without them?
Old Apr 12, 2008 | 01:49 AM
DarkBrew's Avatar
Extraordinary Engineering
Which strakes?
I have used RX8strakes version and they can scratch the paint without the tape under them.
None of the others need the tape. Right now I have the rotary13b1 strakes.
Old Apr 12, 2008 | 03:20 AM
robrecht's Avatar
RX-8 Strakes recommends double sided tape or larger screws when their metal screws into brittle plastic fail. I too am worried about hurting the finish with the plastic directly against the fender but I don't think double sided tape is a good solution. A Mazda parts guy told me that harmed the finish on many cars with their original strake design. I think I'm going to try the redesigned Mazda strakes. I heard they have a rubber surface against the paint.
Old Apr 12, 2008 | 11:45 AM
fatmanyee's Avatar
Thanks for your posts...
DarkBrew I have the 13B1 strakes too.(I have a question for you... were the strakes perfectly flush to the frame? the ones on the left side were quite off)
Old Apr 13, 2008 | 01:13 AM
nope.
just be careful washing them..
Old Apr 13, 2008 | 08:45 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
RX8strakes in use here without the tape. As Swoope says, just be real careful when washing. I haven't noticed any paint damage from not using the tape and mine have been on over two years now.
Dave
Old Apr 15, 2008 | 01:12 AM
fatmanyee's Avatar
Mazurfer... nice ride!! Thanks for the pics
Old Apr 15, 2008 | 05:59 AM
Mazurfer's Avatar
Thanks. I need to change those pics as they are slightly out of date. Just some minor changes, but need to take some more.
Old Apr 15, 2008 | 10:41 AM
laythor's Avatar
I zoom therefore I am.
OEM strakes come with double sided tape already installed on the strakes.
Old Apr 15, 2008 | 09:33 PM
robrecht's Avatar
I know the original version of the OEM strakes used double-sided tape, but what about the newer version OEM strakes?
Threshermal
Apr 15, 2020 09:43 PM
LB2739
Jul 9, 2019 02:25 AM
Brokegang
Jan 3, 2016 12:45 PM
mitchrx8
Sep 13, 2015 08:05 AM
wayloco
Sep 1, 2015 09:03 PM
