Radio Wiring Harness Diagram
Old Apr 11, 2008 | 07:40 PM
BigOLundh's Avatar
#1 Legend
I need a copy of the oem radio wiring harness diagram for an 05 GT Package RX8 (Bose System).
If someone can post it up - that would be great. Hoping to get this done this weekend, but if not... i'll just grab it from the dealership next week.
Old Apr 12, 2008 | 12:23 AM
http://miata.fosketts.net/index.php?..._Audio_Pinouts
I think this is what u've been looking for. Its the same.
Old Apr 12, 2008 | 09:50 PM
BigOLundh's Avatar
#1 Legend
those are all for miatas. i dont want to chance it - so lookin specifically for the oem rx8 radio wiring harness diagram.
Old Apr 13, 2008 | 11:40 AM
Jon316G's Avatar
Grasshopper
Save this link... very useful:
http://smrmicro.com/rx8servicemanual/
You can save each page as a PDF (in case the site goes down for whatever reason... good to have a hard copy).
I believe what you are looking for is under Electrical in section J.
Old Apr 13, 2008 | 08:50 PM
BigOLundh's Avatar
#1 Legend
Good Info man. thats gonna be very useful.
A couple of people on our local forum found this. Its a simplified explanation for just the Radio Head Unit...
http://www.modifiedlife.com/car-ster...004-mazda-rx8/
Radio Constant 12V+ Wire: Blue/Red
Radio Switched Ignition 12V+ Wire: Green/Orange
Radio Ground Wire: Black
Radio Illumination Dimmer Wire: Red/Yellow
Radio Antenna Trigger Wire: N/A
Radio Amplifier Turn On Wire: N/A
Front Speaker Size: N/A
Front Speaker Location: N/A
Left Front Speaker Wire (+): Red
Left Front Speaker Wire (-): White
Right Front Speaker Wire (+): White/Red
Right Front Speaker Wire (-): Yellow/Red
Rear Speaker Size: N/A
Rear Speaker Location: N/A
Left Rear Speaker Wire (+): Purple
Left Rear Speaker Wire (-): Pink
Right Rear Speaker Wire (+): White/Blue
Right Rear Speaker Wire (-): Black/Blue
Old Apr 13, 2008 | 09:48 PM
Jon316G's Avatar
Grasshopper
Thanks for sharing that link... never seen it before.
Old Apr 13, 2008 | 11:08 PM
Is the same ... I followed it and mine work just fine ...
ymmv tho ...
Old May 7, 2014 | 06:06 PM
derut's Avatar
what one is for a 06 Bose one or is it the same one
Need help
Old May 7, 2014 | 09:33 PM
nate.the.great's Avatar
for a Bose system, you need to use the pre-amp out on the back of your stereo. do not just wire up the harness that comes with your stereo or you'll double-amp.
Old Aug 10, 2015 | 03:15 PM
BradyMayhew's Avatar
06 RX8 Bose system
I can't verify every wire but I just finished splicing a line out converter to my amp to power my sub and I can tell you that these worked for me and I couldn't find my exact diagram anywhere. I even had my Mazda dealer email me the diagram they have for the bose system and not all the wires matched up it was interesting. Anyways hope this helps, and remember to splice in before the amp otherwise your signal will be weak and it wont sound right. Cheers!
Left Rear (+) Purple
Left Rear (-) Pink
Right Rear (+) Blue/White
Right Rear (-) Blue/Black
Ignition Switch Wire = Pink/Black
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
Olorin2
20
Mar 13, 2016 11:01 AM
CMRine04
Sep 23, 2015 09:31 AM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
