Your ground of choice in the engine bay?
Old Apr 11, 2008 | 10:02 AM
TheWulf's Avatar
My 8 looks like a Smurf
Just wondering what your ground of choice would be in the engine bay when boosting your battery. Maybe it's just the bad lighting in the garage I'm in but I can't spot a decent ground that's far enough from the battery.
And yes I read the ground threads But none of them address the booster cable preferred ground.
Old Apr 11, 2008 | 10:05 AM
staticlag's Avatar
The Professor
negative battery terminal, unless its encrusted in gunk - terminal is usually the best choice.
Old Apr 11, 2008 | 10:11 AM
TheWulf's Avatar
^ Yea that what I used to do before I knew anything about cars but I heard from a lot of people that a chassis ground was a better choice.
/not a mechanic so don't take my word for anything
//learning!
StealthTL's Avatar
Metatron
Negative terminal is usually not recommended - you want the first and last connections in the circuit to be on the engine block, or anywhere except right on top of the battery. Unusual discharge conditions will fill the battery and area with hydrogen and sparks should be avoided.
I like the alternator bracket, you can always count on a good ground there.
Old Apr 11, 2008 | 10:14 AM
TheWulf's Avatar
That's what I'm using right now. I figured something farther away from the battery would be better (sparks?)
Old Apr 11, 2008 | 10:19 AM
staticlag's Avatar
The Professor
Sweet! I never knew that, always good to learn something new.
Old Apr 12, 2008 | 01:18 AM
BMonkey's Avatar
Hm, I was under the impression that grounding wasn't an issue in the 8. I just keep some peat next to the PCM module to be safe though...
BigMikeATL
May 26, 2016 12:31 AM
uZu
Dec 30, 2015 12:35 PM
rx8inator
Sep 1, 2015 07:18 PM
rx8inator
Aug 14, 2015 10:53 PM
iSki123
Jul 27, 2015 12:41 PM
