Speed bleeders
Old Apr 11, 2008 | 07:30 AM
tskeltonPGA's Avatar
Speed bleeders
ok so a few quick questions about these things....
1) once you install them you leave them there??? you don't replace the factory screw??? thats how the website made them sound
2) what size /part number do we need...yes i have been looking
thanks!!
Old Apr 11, 2008 | 08:11 AM
SouthFL's Avatar
From SpeedBleeder:
Rear: SB1010 M10 X 1.0
Front: SB8100 M8 X 1.0
From Russell:
Rear: 10mm X 1.0 Part# 639560
Front: 8mm X 1.0 X 34mm Part# 639550
I've found these to be a replacement/maintenance item if you're seeing intense heat cycles (tracking the car). Good replace them every year as a precaution.
Old Apr 11, 2008 | 08:48 AM
brilliant
thanks!
Old Mar 17, 2020 | 08:53 AM
ThomasThicc's Avatar
How to remove factory bleed screw
Originally Posted by SouthFL
From SpeedBleeder:
From Russell:
how do I remove the factory clutch bleed screw? I can't get it to come off
Old Mar 17, 2020 | 09:23 AM
it screws right out normally. You can’t get it to come out completely or to turn at all?
Old Apr 24, 2020 | 09:33 AM
Got it off, my bad, was being stupid. Sorry for the late reply.
Old Apr 24, 2020 | 01:18 PM
I expected as much.
no problem
Tony Yayo
Sep 26, 2021 03:05 PM
JRichter
General Automotive
26
Dec 19, 2008 08:34 AM
Paul_in_DC
9
Nov 27, 2006 01:56 PM
cerealspiller
Apr 7, 2005 03:33 PM
