wtb stock sway bars
wtb stock sway bars
yep, you guessed it. Miata guy here looking for a set so the car can handle as well as an rx-8
, so PM me if you have some. Would perfer to have endlinks and bushings as well. Thanks!
You need to use your MX-5 end links on an MX-5. RX-8 sport sway-bars will over power your stock springs and shocks. But it's your ride! Sport sway bars have the yellow paint color code. Use rubber bushings if you use sport bars.
Best of luck.
Info 2wheeled
Hey, just call Jason @ 1-800-223-5439 ext 141. I just bought a set. Front is $ 100.12 rear was 63.??. Less than $164.00 shipped to me in AZ USA. Than PM me for the part #s for the GOOD bushings from Eibach. I'm guessing at this but about 90% of RX-8 come with the upgraded susp.. Only the very base w/ an auto comes with the sway bars your looking for! I spent a long time looking for a used set. Just spend the $$$ and buy them new.
Hers 07 GT w/ "Base" F & R bars.
His 06 Sport w/ "Base" F bar & "Sport" R bar. W/ just a tad of over steer.
Both w/ LS Diff. and same tires.
MM
MM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
