NE RX-8 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, WV, MD, VA, OH
Forced Induction passing emissions please help
Old Apr 9, 2008 | 11:41 PM
Tdubzy's Avatar
Does anyone know if a turboed Rx-8 would pass emissions in Massachusetts? I have researched, and get all sorts of answers. If so, is there only certain turbo kits that will comply? I was thinking the protech turbo kit. What about a supercharger? Will a Pettit supercharger pass?
Old Apr 10, 2008 | 07:31 AM
Feras's Avatar
the Doctor
there is one way to find out, take it in and tell us how it goes.
Old Apr 23, 2008 | 11:16 PM
jjc3925's Avatar
guess noone in mass has a turbo kit yet lol
Old Apr 24, 2008 | 08:59 AM
dmc27's Avatar
doin' the bull dance
I don't know the answer. But I would suggest that you talk to some local shops. Many times the custom shops and tuner shops will, um, be able to ensure you pass.
Old Apr 24, 2008 | 09:14 AM
mysql's Avatar
Doppelgänger
depends on what your emissions check involves.
if they are checking for a CEL, then you'd pass if you run the Ultimate or AccessPort for fuel management, since those are the only two that can function without a cel.
If you're catless, then only the AccessPort can mask out CELs.
If they do a visual inspection, you might pass with an exhaust mounted turbo system since it's out of the way and hidden.
If they check for emissions in your exhaust pipe, then if you're running the stock cat, or a high flow cat, then you can pass with a turbo too.
So the reason why no one has a definite answer for you, is because the answer depends on what setup you go with.
Old Oct 10, 2008 | 05:11 PM
GaMEChld's Avatar
Registered Noob
If you used an OBDII Scanner to clear the codes, would it then be passable through OBDII inspection? Or only AccessPORT? And even with the AccessPORT, does that work regardless of what the exhaust sensors might be reading? It doesn't matter if its catless?
Old Oct 13, 2008 | 11:07 AM
rkostolni's Avatar
If you clear the codes right before going, their equipment will notify them that the computer hasn't had enough drive cycles to accurately determine the state of health of the emissions equipment. So no, that won't work.
Old Oct 14, 2008 | 11:42 AM
GaMEChld's Avatar
Registered Noob
And clearing the codes everytime you drive wouldn't matter either?
Old Oct 14, 2008 | 12:05 PM
Greenblurr93's Avatar
Sotally Tober
correct, if you clear the codes you need somewhere between 3-5 drive cycles or the computer wont pass you. you can try the defouler mod, that has worked for some... the best way is to get the Cobb AP
Old Oct 14, 2008 | 12:50 PM
gregs's Avatar
Pull My Finger
i live in so cal and when my smog comes up i will plan on trying to pass emissions with my greddy turbo kit...i have cobb ap and at the time will using my stock cat. (theres quite a bit of places here that will accept overlooking the visual test)
Old Oct 14, 2008 | 06:05 PM
GaMEChld's Avatar
Registered Noob
yeah, I just don't want to shell out money for an AP since I already have an Int-X. I might be able to borrow one if I find a local who has it though.
Someone mentioned to me that defouler method, I didn't really understand though, how does that work? I gotta mod the sensors basically? Is that a pain?
Old Oct 14, 2008 | 09:55 PM
jfxp's Avatar
Rotor nut
Best way is to find an emissions friendly shop and throw them extra cash. I wouldn't ask just anyone though as you could get into some trouble. If it wont pass they can always run w/o signal (not plugged in) however this only works for a year bc a signal is required the following year. This is the way it works in Pa anyways, too bad you dont live around here.
Old Oct 15, 2008 | 06:03 AM
Sotally Tober
paying someone wont work anyway because they NEED to plug it in if they want the sticker to print out... the way the fouler mod works is you take a spark plug defouler and screw it into the o2 bung, then put the o2 back in.... the theory is the sensor is out of direct flow of the emissions gases so its only sampling a small amount of gas, and therefor thinks your emissions arent as bad... look here for more details.
https://www.rx8club.com/series-i-tech-garage-22/o2-sim-works-mod-edit-read-thread-doesnt-work-140873/
Old Oct 15, 2008 | 01:32 PM
GaMEChld's Avatar
Registered Noob
Thanks for the link, I'll read up. Yeah it's a big pain in NY, everything is kept track of in databases.
gwilliams6
General Automotive
60
Nov 3, 2015 02:50 PM
br0wm
Oct 24, 2015 11:06 PM
r-enzyme
Oct 1, 2015 01:27 AM
stickmantijuana
10
Sep 13, 2015 11:28 PM
