Large gap between bumper and hood?
Old Apr 9, 2008 | 10:35 PM
Raptor2k's Avatar
Club Marbles Member
I just got my car back from the body shop to repair my bumper. Debadged it too, I think it looks pretty good.
Once I got home I noticed the gap between the hood and bumper was at least twice as thick. What could of caused this? Did they tight the bumper on incorrectly?
Old Apr 9, 2008 | 10:58 PM
Fortunate Few's Avatar
Irollerblade.
try taking it off and putting it back on yourself if its the same then they messed it up.
Old Apr 10, 2008 | 02:03 AM
Mazdaspeed RX8 ver2's Avatar
i dont think that the case, look right under the headlight, there are what seems to be clips where you have the put the front bumper on to lift it a little so that the gap between the hood and the bumper will be removed. (this is just my hypothesis), i have the same issue and every time i wash my car, i see those metal clips and correlate it with the gap between my hood and bumper. you should notice a slight gap below the headlight as well.
Old Apr 10, 2008 | 04:53 AM
ЯX-8's Avatar
https://www.rx8club.com/showpost.php...20&postcount=2
Old Apr 10, 2008 | 05:00 AM
DOMINION's Avatar
I don't buy Kool-Aid
Sounds like you got a non-OEM bumper or hood going there. I had a rep front bumper after my first wreck on my old AT 8 and the fitment sucked!
Old Apr 10, 2008 | 01:33 PM
Raptor2k's Avatar
Club Marbles Member
Thanks, that worked.
Old Apr 10, 2008 | 05:50 PM
Shadow12one's Avatar
hahaha replica OEM parts
Old Apr 11, 2008 | 05:10 AM
ЯX-8's Avatar
All fixed? I have the same problem, I need to fix it over the weekend..
Old Apr 12, 2008 | 02:38 AM
i feel you, i have something to do on my time off tomorrow now. haha
Old Apr 12, 2008 | 09:46 AM
ЯX-8's Avatar
Same problem? Mine isn't that bad, it's just once I took off my body kit off and put the oem back on, I just put it on in a hurry basically without making sure that there wasn't a gap.. So, I just left it alone until later!
Old Apr 12, 2008 | 01:28 PM
i had the same problem, when i got my 8 back from the body shop after installing the mazdaspeed front end, there was no problem at all, i removed the bumper to install the mazdaspeed cai then when i reinstalled it, bam, gap. never had too much of an issue with that, been pretty lazy to try to fix it until i saw that post with some instructions that solves the problem. but im selling my mazdaspeed front end soon and don't know if i should fix it now. haha
Old Apr 12, 2008 | 10:03 PM
lift the hood, pull the plastic air plate that's at the top center between the front bumper cover and engine bay, there is a plastic rivet and pair of screws on each side that serve to secure the top center portion of the front bumper to the chassis, loosen the screws and pull the plastic rivets, the holes are enlarged to allow that portion of the bumper to moved in/out, set to proper position and tighten screws then check the fit, once in place then reverse procedure
Old Apr 18, 2008 | 09:47 PM
JOLIET WANKEL's Avatar
Xboxgametag:Chafed Banana
what he said. i just had my bumper off yesterday to install cold air. there is 4 screws. just loosen them and then slightly tighten one on each side so when you move the bumper around it stays. now close your hood and position the bumper where you want it. pop the hood again and then tighten all 4 screws down.
Jst4fun
Apr 17, 2021 07:43 AM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
Digitz0070
Oct 7, 2015 12:43 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 5.00 average.
