Flooding
Old Apr 9, 2008 | 07:31 PM
SHSboy's Avatar
Flooding
I've already read the above post, but I still have questions. The other day, I was in the midst of test driving a Tiburon when I saw the RX-8. After returning the car to the dealer, we went to drive the Mazda. I loved the how the car drove, how it handled, the ride, etc. Then, I went to check for problems of the car and found four recalls for the 04. Should the recalls show up on a car fax, and if not, will the dealer automatically fix them? I know the dealer talked about the car already went through servicing, but a recall never appeared on the car fax. Also, flooding concerns me a tad. Would someone mind explaining me the difference between a rotary engine and an engine with pistons? Thanks for the comments and posts.
Also, how reliable is the car in your opinion?
Old Apr 9, 2008 | 09:05 PM
Jon316G's Avatar
Grasshopper
This site should give you an understanding with Rotary engines:
http://auto.howstuffworks.com/rotary-engine.htm
Flooding is an "issue", but not that difficult to get used to. When you start your car, leave it on for a few minutes. Its recommended that you let it sit for 10 minutes or rev it up to 3K RPM for 3 minutes (correct me if I'm wrong). I've heard that people redline it before shutting it off. I honestly just wait until the engine is warmed up (referring to the temp gauge on the dash) and its been fine.
Just be careful when you give your car to a shop... make sure you inform them that they need to let the engine warm up before shutting it off.
Go48 posted a nice printable sheet that you can keep with the car and tape it to the dash when you take it into shops.
Its post #10 in this thread:
https://www.rx8club.com/series-i-trouble-shooting-95/bodyshop-flooded-my-car-eerrrgggg-142229/
Old Apr 9, 2008 | 09:08 PM
SHSboy's Avatar
Well, I've read around, and it looks like as long as you warm your car up and rev it a little to 3k you'll be fine.
Old Apr 9, 2008 | 09:11 PM
Jon316G's Avatar
Grasshopper
The dealer can also show you all the recalls and TSBs that have been performed on that car. I once printed out a bunch of TSBs and took it to the dealer while it was still under warranty and they printed out a sheet of everything that was already performed.
Old Apr 9, 2008 | 10:35 PM
SHSboy's Avatar
oops, I feel like an idiot. That advertising got in the way, and I missed your post about flooding Jon. I really enjoyed driving the RX-8, and I'm sure that everything will work out. Thanks!
Old Apr 9, 2008 | 10:36 PM
SHSboy's Avatar
Also, what's considered cold for flooding, I live in Virginia, and It's rare if it ever gets below 0 Fahrenheit.
Old Apr 10, 2008 | 12:50 AM
Jon316G's Avatar
Grasshopper
Not completely sure what you mean... but I believe you are referring to when I said to allow time for your engine to "warm-up". Flooding can occur at any outside temperature. Doesn't matter if its 10 or 110 degrees, just give your engine some time to run before shutting it off.
I only mentioned the temp gauge because its almost like a measurement of time for me... when the needle is in the center, then I know I've had the engine running for a good amount of time and can turn it off without being flooding. Can you turn it off before the needle is centered... sure. But its a good reference for me.
Old Apr 10, 2008 | 10:18 AM
tskeltonPGA's Avatar
saying cold isn't referring to the air temperature...it's referring to the engine temperature...as long as your temp gauge shows you are warmed up you are good...mine gets a little below the middle of the gauge...i was also told to rev it to 3000 rpm and then turn it off...it has been starting up a tad bit easier since i began that practice as well
Old Apr 24, 2008 | 10:24 PM
SHSboy's Avatar
okay, I got my rx-8 and I'm loving the car. How long should I let the car warm up, and where should I let my needle go before driving it? thanks.
Old Apr 25, 2008 | 03:56 AM
Jon316G's Avatar
Grasshopper
Good to hear you like your 8.
You can start driving right away, just don't try to drive it hard (red-lining) for roughly 5-10 minutes (depending on outside temperature).
Going back to my previous post... thats when I personally use the temp gauge as a visual indicator that the engine is warmed up and I can be a little more aggressive with it.
Old Apr 26, 2008 | 01:57 PM
SHSboy's Avatar
I see, thanks for the answer. You only need to warm it up if you are going to back it up and turn it off, right?
92trbolzr
May 18, 2025 09:04 AM
DylanForbes
25
Oct 31, 2017 05:47 PM
fistofmeat
Oct 7, 2016 12:15 PM
Danield97
Oct 10, 2015 05:58 PM
iphil
Sep 21, 2015 10:49 PM
