rx8m04
04-09-2008, 03:38 PM
does anyone know if you can turn off the check engine light by unplugging the battery for an hour? i had a spark plug issue ......so i changed those but now i just want to get that enginge light off.
View Full Version : can you turn off check engine light by unplugging the battery for an hour? rx8m04 04-09-2008, 03:38 PM does anyone know if you can turn off the check engine light by unplugging the battery for an hour? i had a spark plug issue ......so i changed those but now i just want to get that enginge light off. shaunv74 04-09-2008, 03:39 PM Are you sure that solved the problem? I would go to an autozone and pull the code to find out what the problem is. When you fix a problem the CEL should go away. rx8m04 04-09-2008, 04:07 PM actuall i had it at a dealer and they said i needed new plugs but then they wanted to charge me 300$ to do it so i just got out of there and ordered them myself and put them in. everything is good to go now just that light is on. i went to advanceauto today and they didnt have a CAN scanner only OBDII. so no help there but one of my freinds said to just unplug it for an hour and then it should go away. staticlag 04-09-2008, 04:10 PM unplugging it does make it go away. Butch Brown 04-09-2008, 04:12 PM disconnect both + _ cables from battery then touch them to each other then reconnect to battery. After you start your car you will need to turn steering fully left then fully right, turn off ignition and restart, that will clear the TCS light. rx8m04 04-09-2008, 04:29 PM disconnect both + _ cables from battery then touch them to each other then reconnect to battery. After you start your car you will need to turn steering fully left then fully right, turn off ignition and restart, that will clear the TCS light. i will try just unpluggin it and then if that doesnt work i will try what you said.....what does turning left and right do and why would i have to touch the +- together. im not doubting im just interseted. im sure there are different ways to do this. 4 years to Supercharge 04-13-2008, 06:18 AM Turning the wheel full lock left and then right recalibrates the dynamic stability control. Mazurfer 04-13-2008, 09:29 AM ANYTIME you unplug the battery you will have to do this reset or you will get the DCS/TCS lights. Turn car to on(not start), turn wheel all the way to right, then all the way to left, then key off, then you can start as normal. nycgps 04-13-2008, 10:33 AM this op failed. Go48 04-13-2008, 01:02 PM Rx-8 Owners Manual: "NOTE: If the battery is disconnected, the DSC will be inoperable. In this case, the DSC OFF indicator light flashes and the TCS/DSC indicator light illuminates. To make the DSC operable, do the following procedure. 1. Turn the ignition switch to the ON position. 2. Turn the steering clockwise fully, then turn it counterclockwise fully. 3. Make sure the DSC OFF indicator goes off. 4. Turn the ignition switch to the OFF position, then turn it to the ON position again. 5. Make sure the TCS/DSC indicator light goes off. If the TCS/DSC indicator light and the DSC OFF indicator light remain illuminated even after turning the ignition switch to the ON position, consult an Authorized Mazda Dealer." 4 years to Supercharge 04-13-2008, 07:51 PM :) It works either way. :p: rx8m04 04-14-2008, 08:30 AM Thanks everyone! Spinning Sushi 04-14-2008, 11:01 AM You made two threads with the same title and asked the exact same question... http://www.rx8club.com/showthread.php?t=142876 Spinning Sushi 04-14-2008, 11:02 AM Oh, I forgot to mention that you also posted in the wrong section of the forum.... RX8 Newby 11-21-2009, 08:36 PM You guys are great. I have been trying to figure out how to get those two lights off! |
