whining when starting
Old Apr 9, 2008 | 10:27 AM
wvumtnbkr's Avatar
Ewwww Shit you like that!
Good Day!
I sent my car in for a cat replacement, which they did, now when I start it it whines really loud! There is an electric motor running that is super loud (sounds like a turbo spooling or something). The motor is located near the passenger side strut tower. It runs for like 10 or 20 seconds and then shuts off. This just started after they replaced the cat.
Anybody know what it is? Is it a problem, or is the car supposed to do this? It never did it before (I've had the car for 1.5 years).
Rob
Old Apr 9, 2008 | 11:55 AM
savedsol's Avatar
Carbonormous
Air pump. They all do it.
Old Apr 9, 2008 | 12:12 PM
Kane's Avatar
Senior Member
Air Pump; if it is REALLY loud; check and see that they connected it back the correct way.
Old Apr 9, 2008 | 05:15 PM
DanRedRx8's Avatar
What a Nice Ass
its called the secondary air injection pump.... its used to heat up the cat faster with cold starts.... its a tiny electric motor that spins two thin metal "fans." My cat failed on me aswell so i gutted it and now i am running an "oem midpipe." The whine also happens with me so i took the sucker apart and oiled it and made sure everything was balanced.... did nothing... still whines.... i would say do not worry about it........ just every now and then check to make sure the unit is not producing any smoke or is getting hot as that would mean the metal fans are rubbing against the plastic molding....
Hop this helps
Old Apr 9, 2008 | 05:24 PM
bose's Avatar
Reginald P. Billingsly
I had the same thing, sounds like we all do. It took me a few minutes to convince myself it was nothing, and I was right whaddayano.
Old Apr 9, 2008 | 10:31 PM
Ja, you should have seen Jedis look on his face!
It looked as if he did a dump in his shorts.
I told him its normal.
Old Apr 10, 2008 | 10:16 AM
wvumtnbkr's Avatar
Valve?
What Valve?
Audio Concepts ATL
Sep 26, 2021 01:59 PM
harithac
Aug 26, 2015 09:24 AM
GrAfiX
Aug 24, 2015 08:08 AM
poppinparker
Aug 10, 2015 09:20 AM
T_Mags
Jul 24, 2015 11:29 AM
