Front-bottom chassis cover part name?
I just noticed that there a plastic cover that's dangling from just under the front grill. Part of it is broken, so it lays low, almost touching the road surface. It seems to cover some areas of the lower front chassis, mostly the front axis.
Anybody has any idea about the name of this part? Can it be replaced easily?
i dont know the right name for it but it is very easy to take off and put a new one on.. all you need to do is take off the front bumper, theres a DIY on it, and after you take it off you can see where it all connects. you might not need to buy a new one. go ahead and take it off and you might be able to use some zip ties maybe and fix it that way. it will be much cheaper and pretty easy to do
AllSeeingChris
Aug 16, 2015 12:35 PM
