Custom Turbo kit??
Old Apr 7, 2008 | 09:24 PM
chromatica's Avatar
Custom Turbo kit??
So here's the deal. I've got the stock TD04 turbo from the WRX I used to have.
Approximately how much would it cost to get this thing bolted up an tuned on my 8?
Any one else ever do anything like this?
I'd need: injectors, intercooler, bypass valve, piping....... what else?
Old May 16, 2010 | 07:12 PM
BSchwemer's Avatar
Stock subie turbo is too small.
check out the FS thread in my sig for information on parts needed. i built my own kit from scratch as have a few other members here. expect to pay about $4K+ if you build your own kit.
Old May 16, 2010 | 07:16 PM
you're going to need a lot.
first off, you'll need to look at flow charts to see if that particular turbo would even be efficient enough to run on our car.
what hp are you looking for?
what are your goals for the car? street car? track car? auto x ? dyno queen?
budget?
where are you to mount the turbo? you'll need a manifold and depending on whether your'e going top mount or not, that changes a few things.
take a look around in the major horsepower subforum and you'll get a better idea of what is required.
Personally I wouldn't boost an RX-8 until you've addressed things such as Ignition, cooling, and engine management.
Old May 16, 2010 | 08:35 PM
Turblown's Avatar
Boostin'
As said a subie turbo is way too small. What all is currently done to your vehicle?
Expect to do a ignition upgrade, clutch, exhaust system, ecu, injectors, fuel pump, fmic etc... It takes a lot of parts...
Old May 17, 2010 | 10:35 AM
09Factor's Avatar
Original Turbo 'd Auto !!
Wow. Threadsurection !
Chromatica hasn't been on here since 4/28/2008.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Learners_Permit
Sep 27, 2015 07:38 PM
Digitz0070
Sep 27, 2015 07:49 AM
Digitz0070
Sep 25, 2015 10:58 PM
