View Full Version : 2 questions about rx8
Sushi
04-07-2008, 11:37 AM
Hey guys. My headlights have a almost dirty look like a yellow tint to them. I have cleaned them throughly on the outside, but I guess it is in the inside. What can I do to clear that up? Do I have to buy new ones? Also you know that little chrome plate that says RX-8 on the door frame on the floor next to the seat? What is that called? I have one missing and would like to buy another, is there a place that sells them?
Bootleg
04-07-2008, 11:41 AM
for your headlight, get some of this and follow the directions. it works pretty well for it's cost.
http://www.meguiars.com/estore/products/product_G12310.jpg
the other peice you're talking about is called the door sill.
Sushi
04-07-2008, 12:19 PM
Thanks man. Does that stuff for the headlights work well? Also that will get the dingy look off the inside as well, or do I need to remove the headlight and do it? and if so how hard is that?
j67345
04-07-2008, 12:42 PM
There is a TSB for the insides of the headlights getting cloudy. I had mine replaced under warranty a couple years ago. You might check that out.
RACESHARK
04-07-2008, 08:36 PM
rx8strakes.com sells the door sill.
raizen82
04-07-2008, 09:04 PM
try going to the dealership and have it replaced. i got mine replaced because of the same thing. it's not condensation but some form of discoloration on the inside of the housing. mine still has warranty.
Sushi
04-07-2008, 09:05 PM
Thanks guys, I used the Plastex and it looks much better. I might sand them down a little and redo it to make it look atlittle better. But much nicer.
CarAndDriver
04-07-2008, 10:12 PM
If polishing the exterior does not work, I think youll have to replace.
