Wideband routing
Old Apr 7, 2008 | 07:25 AM
tskeltonPGA's Avatar
Wideband routing
ok so i just purchased a turbo xs exhaust and it has a bung already on it for a wideband O2 sensor welded onto it...it is right before the exhaust pipe bolts to the y pipe by the mufflers...is this an ok place? if i get a high flow cat or race pipe later will i need to move it?
also...i haven't received my aem eugo yet but it is in the mail...what is the best way to route everything from under the car into the cabin to the gauge? i have searched...sorry if i didn't find it...thanks for the help in advance!
Old Apr 7, 2008 | 07:49 AM
mysql's Avatar
Doppelgänger
mine is on a catless midpipe.
I have the uego, and I don't know if the wire is long enough to run to the back of the car.
Old Apr 7, 2008 | 08:05 AM
so i may need to plug up that bung and get one placed else where it looks like huh??? ****...ok...well question...the bung is already threaded and everything...any idea on the best way to plug it up then...just get a big screw????? jk by the way
Old Apr 7, 2008 | 09:00 AM
staticlag's Avatar
The Professor
Yeah, you just get a big bolt and that will plug it up.
You can extend your wideband, just cut the wire, and crimp in a 3 or 4 foot extension on each of the wires inside the line. Make sure you use weathertight crimps if the connections are going to be outside the cabin. Easiest way to route inside is through the shifter hole, but it will take a lot of wire. The way i did it was I zip tied it to the top of the tranny, heat shielded the part that came closest to the cat, then run it to a hole I made near the trunk release cable on the driver's side firewall.
Old Apr 7, 2008 | 09:48 AM
awesome thanks...i'm going to look more on this question but...where is the best place to get the most accurate a/f readings...b4 the cat...after the cat...of way the hell down near the y pipe???thanks
Old Apr 7, 2008 | 03:14 PM
staticlag's Avatar
The Professor
Your wideband instructions will say the optimal mounting location. But generally optimal location is dependent on temperature. Ideally placed in a location that is not too hot. Stock O2 narrowband location is good. Preferably before the Cat, but theoretically it shouldn't make a difference.
yurcivicsux
192
Sep 12, 2017 10:54 PM
Stubbs
Sep 27, 2015 04:06 PM
sccarally
Gulf RX-8 Forum
Sep 27, 2015 03:47 PM
yapakanichi
20
Sep 10, 2015 07:17 AM
