Mazsport cooling fan, where should the 2 hose clamps go to?
Old Apr 5, 2008 | 08:10 PM
R888's Avatar
WedsSport Member
Exclamation Mazsport cooling fan, where should the 2 hose clamps go to?
Hello, I have no clue that where the 2 hose clamps should go into "cooling fan # 1" and "cooling fan #2" as descirbed in the instruction
The instruction doesn;t comes with the diagram
Can anyone please upload a pic / a diagram for me please.
Thank you for your help.
Old Apr 5, 2008 | 08:13 PM
MazsportScott's Avatar
Mazsport.net
The two hose clamps should hold the recently cut hose ends to the assembly. The relays go into the factory fuse box replacing the factory relays. Hope this helps, Scott
Old Apr 5, 2008 | 08:16 PM
expo1's Avatar
He's as bad as Can
Photos in this post
https://www.rx8club.com/showpost.php...1&postcount=17
Old Apr 5, 2008 | 08:20 PM
R888's Avatar
WedsSport Member
Thanks for the quick repsonse, Scott.
The 2 black adaptors should go where? into the ECU box..
Not sure which relays or fuse should I unplug and plug the 2 black adaptors. Please let me know again.
Sorry for the trouble again
Old Apr 5, 2008 | 08:21 PM
R888's Avatar
WedsSport Member
Expo1, I own you one..
Thanks a bunch!!
Btw, off the topic. Did you get the 2 ohms resistor for the bypass airbag light method?
Old Apr 5, 2008 | 08:27 PM
expo1's Avatar
He's as bad as Can
I don't wish to mess with that stuff. Its only an issue when I am at the track using a race seat. I can deal with the light for a weekend.
Shankapotamus3
Mar 14, 2021 03:53 PM
05rx8mazda
Nov 28, 2015 09:42 AM
Evan Gray
Nov 24, 2015 01:00 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
