View Full Version : Ideas for a BOV recirculate fitting?
tdiddy
04-02-2008, 08:48 PM
I am thinking about trying to recirculate my BOV and I am looking for ideas on how to attach a 1" silicone hose to the silicone 90 that is between my MAF and my turbo in this picture. I would like as little of an airflow restriction as possible. Any ideas would be greatly appreciated and links to the parts would be even better. Thanks!!!
http://www.rx8club.com/attachment.php?attachmentid=117958&d=1206728020
Romeo
04-04-2008, 12:24 PM
thats tough. Ive heard people tapping right into the Silicone.... but I dont know how solid that is. especially with a 1" hose.....
hmm, good question.
mysql
04-04-2008, 12:42 PM
not much space there, but you might be able to squeeze in a metal 90 elbow and tap into that...
http://www.atpturbo.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=tp&Category_Code=PPB
if not, you might also be able to get a one off made that has a 90 elbow coupler with a 1" hose coming out of it. my friend with an audi s4 has silicone hoses that look like that.
mysql
04-04-2008, 12:44 PM
like ..
chickenwafer
04-04-2008, 12:48 PM
I would first flip the BOV around 180 degrees so it's facing the back of the engine compartment. The SSV is held in place with a PITA snap ring so that's easy enough to do, you don't have to worry about bolts lining up and such.
Then a metal pipe like Jason suggested would probably be the best bet.
mysql
04-04-2008, 12:51 PM
and ceramic coat those pipes...
today I'm going to try out the duplicolor spray paints that have ceramic in it. Ceramic paint and ceramic enamel .. worse case I wasted $15 for 3 cans of the stuff.
Romeo
04-04-2008, 01:25 PM
yeah, deff turn it 180degrees, lol
mine goes 180 degrees back, around, loopty-loop and down, lol
(camera phone pic)
http://img219.imageshack.us/img219/1482/recirckb1.jpg
but it gets the job done. :)
I would really look into a 90 degree silicone hose with a 1" tapping on it. Im sure somebody makes one.
staticlag
04-04-2008, 02:10 PM
http://www.marinedepot.com/ps_ViewItem~idProduct~FT1111.html
Long live front mount turbos !!!!
staticlag
04-04-2008, 02:11 PM
So cut the hole, insert the fitting from the inside, screw down the collar, then you can attach some hose to the threaded nipple.
Romeo
04-04-2008, 03:45 PM
awesome!
thats definetley something I would do if I was in your situation. Looks pretty solid and easy to me :)
tdiddy
04-04-2008, 09:39 PM
Thanks for the suggestions. I have something similar to what Static suggested but it will be a while before I get to install anything. Take a look...
http://www.rx8club.com/showpost.php?p=2389816&postcount=322
