Trouble starting
The Former PSNTLSS
Trouble starting
I have noticed recently on a few occasions. When I turn the key it takes a good 3-5 seconds to get the engine to finally turn over.
Any possible reason?
The Former PSNTLSS
Oh boy, Maybe maintaince will come sooner then I thought, I mean the battery turns on and the starter turns but its like the engine just won't catch
The Former PSNTLSS
Its a 2004, I have not flooded the car, and I'm under 34,000 miles. I drive the car at about 7 in the morning to school its about a 5 minute drive. Probably the cause of possible flooding?
go the dealership and tell them you're having lots of trouble starting the car. Sometimes you'll crank the key and it does not start.
(slight exaggeration, yes but it'll help you get that bulletin performed)
Upgraded starter, battery, and spark plugs here you come.
stupid question but i have a friend with the same problem but is out of warranty.... will the TSB still cover it even though hes out? Or will they perform it then charge him? Thanks guys :D
BTW i tried the de-flooding by taking out plugs, drying, putting other ones in. The plugs werent new but not flooded. Nothing worked there...
The Former PSNTLSS
I was gonna schedule maintance to get fluids and tires checked and all and figured when I drop it off I'll explain that I have a very frequent problem of the crank not starting the car, its not all the time but quite often and most random times
same question. ive been havin really slow starts (more cranks than normal). also, will they give me problems cuz i have the RB intake and exhaust?
lol my local delaership keeps boxes of donuts in the loby of the sales dept, next time im there im gonna take the box and walk accross the street to the svc dept and tell them its a gift from the bottom of my heart lol
i had this problem and a good fix was swappin plugs, wires and coils...although im at nearly double your mileage. It desperately needed to be done cause my coils were done andm y plugs were fouled up baaaad. I also did some other maintainance and cleaned the TB and ran seafoam through the BB line. after i was ll done the car ran like a champ and started instantaneously.
since you are under waranty i sugest you go that route but if u cant get the tsb done for whatever reason i suggest you do some of what i did, even if it doesnt entirely fix the problem it should help in some way or another cause thats all stuff which needs to be done anyway.
rx8wankelrotary
Aug 17, 2015 10:42 AM
