19" rim question
Old Apr 1, 2008 | 08:29 AM
thecarter19's Avatar
19" rim question
why does it seem in my searching that the most popular size aftermarket rims people buy are 18". Is this because people want to use their current tires or due to overall weight/performance? Is it because this cost difference between 18 and 19 inch tires? Or does the one inch increase wheel gap and require suspension mods to get a clean look? Im currently searching for some aftermarket wheels and I was wondering the plusses and pitfalls of changing wheel size. I currently have 18" factory set.
Thanks guys
Anthony
Old Apr 1, 2008 | 10:54 AM
pdxhak's Avatar
Official Post Whore
You can purchase 19" wheels that weigh less that OE wheels. FWIW my 19" wheel and tire combo weigh 4lbs less per corner.
Maybe but tires is the last place you want to go cheap. Not implying you would and it is just a general statement.
19" if done right will not decrease or increase the gap. When you +1 on wheel size, you need to size the tire accordingly.
Factory is 225/45/18. My wheels are 255/35/19 and they are very close in size.
You want to keep the rolling diameter as close to the OE setup as possible. This keeps your speedo from being off and more importantly if you are still under warranty, it does not run out sooner. If your rolling diameter is different than stock, you will log more miles on your odometer than has occurred in reality.
LB2739
Jul 9, 2019 02:25 AM
Brokegang
Jan 3, 2016 12:45 PM
hppy4u
Gulf For Sale/Wanted
9
Dec 3, 2015 09:11 PM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
yankeepicker
Sep 11, 2015 05:42 PM
