Alignment tomorrow morning - questions?
Old Apr 1, 2008 | 08:21 AM
Optical TDI's Avatar
I've read several threads on alignment suggestions and there are many different specs for many different applications and how the car will beused.
Suspension mods are: Racing Beat springs and Hotchkis sway bars.
I will be running 2-3 HPDE events per year. They likely will all be at Mid-Ohio. I will NOT be autocrossing the car. I drive it about 700 miles per month and don't mind a small amount of uneven tire wear.
Also, my front bar is set to full hard, and the rear bar to full soft and I'm getting throttle oversteer. So, I was thinking of having a large variance in camber from front to rear so I can set my rear bar to the middle setting.
Please let me know your thoughts to camber, caster, and toe settings. Thanks.
Old Apr 1, 2008 | 11:30 AM
Silver_Surfer's Avatar
I4NI
2-3 events per year? I would opt for the factory settings.
Old Apr 1, 2008 | 12:47 PM
SouthFL's Avatar
The spec I use is far from aggressive, yet the car is very neutral, with predictable rotation while trailbraking. Any understeer at turn-in has been dialed out. Tires don't wear unevenly.
Camber: -1.4 F / -1.7 R
Caster: 6.8
Toe: 0 F / 0 R
Supension: H-Tech springs with Konis set at 50% F, 25% R on stock sways.
I suspected the Hotchkis setup would yield too much oversteer based on the data posted on their website, even at full soft rear. I told that to Hotchkis while talking to them, but they stand behind their settings- who am I to argue with them?
Old Apr 1, 2008 | 03:03 PM
You are correct about the oversteer with the Hotchkis bars. That's why I'm thinking of increasing the rear camber so I can adjust the rear bar to the middle setting.
gwailo
May 14, 2024 06:57 AM
Irvinb16
Sep 11, 2015 10:27 PM
yankeepicker
Sep 11, 2015 05:42 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
