Just changed the Final drive Do I need running in?
Old Apr 1, 2008 | 01:59 AM
WarmFreedom's Avatar
If so, how long required
and what if I dont?
Old Apr 1, 2008 | 02:57 AM
Charles R. Hill's Avatar
Owner of BHR
What did the manufacturer of the gears or your install tech have to say about it?
Old Apr 1, 2008 | 03:53 AM
I didn talk to the manufacturers, becos I ordered from japanparts.com
what do u recomend?
Old Apr 1, 2008 | 10:15 AM
Owner of BHR
I'd probably give it a couple hundred miles.
Old Apr 1, 2008 | 10:18 AM
staticlag's Avatar
The Professor
Assuming it doesn't make any noise or other signs of bad fittment.
Drive it to operating temp. let it fully cool.
Drive it to operating temp. let it fully cool again.
Drive the hell out of it. let it cool.
You're good!
Old Apr 1, 2008 | 10:49 AM
alright thanks!
Old Apr 1, 2008 | 11:54 AM
staticlag's Avatar
The Professor
Its probably a good idea to change the gear oil 10-15K later.
Old Apr 1, 2008 | 09:17 PM
Japanparts.com's Avatar
Japanparts replies
what do u recomend?
The success of the FEED final drive swap has to do with how well your transmission tech. setup the preload/backlash in the crownwheel and pinion assembly
If that's done right, there's *no* run-in period necessary
And no "special proceedure" required other than the initial setup and install
GW
JapanpartsLLC
Old Apr 5, 2008 | 11:53 PM
juikster's Avatar
Im 8 drifting on a budget
alright thanks!
here is the pics
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Skyl3r
Dec 2, 2019 04:51 PM
jay_tibo
22
Sep 13, 2016 08:10 PM
k4thomas
Aug 5, 2015 03:03 AM
