View Full Version : Klepto gets dropped!
chrism 03-28-2008, 11:04 PM Took some pics of his new suspension upgrades....Espelir lowering springs and Carbing rear bar
http://i302.photobucket.com/albums/nn93/chrismarko7/jeff%20gets%20dropped/P3280001.jpg
http://i302.photobucket.com/albums/nn93/chrismarko7/jeff%20gets%20dropped/P3280002.jpg
http://i302.photobucket.com/albums/nn93/chrismarko7/jeff%20gets%20dropped/P3280003.jpg
http://i302.photobucket.com/albums/nn93/chrismarko7/jeff%20gets%20dropped/P3280004.jpg
http://i302.photobucket.com/albums/nn93/chrismarko7/jeff%20gets%20dropped/P3280005.jpg
http://i302.photobucket.com/albums/nn93/chrismarko7/jeff%20gets%20dropped/P3280006.jpg
http://i302.photobucket.com/albums/nn93/chrismarko7/jeff%20gets%20dropped/P3280007.jpg
http://i302.photobucket.com/albums/nn93/chrismarko7/jeff%20gets%20dropped/P3280008.jpg
http://i302.photobucket.com/albums/nn93/chrismarko7/jeff%20gets%20dropped/P3280009.jpg
http://i302.photobucket.com/albums/nn93/chrismarko7/jeff%20gets%20dropped/P3280010.jpg
BigRed 03-28-2008, 11:07 PM it looks very low! how does it ride?
GAMBEAN 03-28-2008, 11:09 PM I like the last pic. nice drop. how is the ride quality compared to the tein's S?
HockeyRX-8 03-28-2008, 11:10 PM Nice drop, man. Now you just need to get some rims.
fd3s777 03-28-2008, 11:17 PM Also need the adjustable front and rear endlinks. Since after your drop, your stablizer bar is not in correct position.
http://www.evo-r.net/product/RX-8/LINK/SE3P.jpg
NgoRX8 03-28-2008, 11:19 PM looks clean! nice drop
fahrfegneugen 03-28-2008, 11:23 PM Nice drop, man. Now you just need to get some rims.
I agree, it looks great, but I think rims would make it the lowering stand out more.
chrism 03-29-2008, 12:14 AM I like the last pic. nice drop. how is the ride quality compared to the tein's S?
the ride quality is very near stock.....i have the same springs and i love them....the tein s-techs are very similar
SayNoToPistons 03-29-2008, 12:34 AM Looks great, but..... Can he survive the BQE???
pdxhak 03-29-2008, 01:19 AM OE shocks? Looks good.
chrism 03-29-2008, 09:20 AM Looks great, but..... Can he survive the BQE???
i hope so considering he lives right off it :)
altspace 03-29-2008, 09:26 AM Wow, that bar hangs really low. How far is it off the ground? I'd be afraid of speed bumps.
chrism 03-29-2008, 09:58 AM 2 inches with the 18's maybe 3 at most
jones75254 03-29-2008, 10:13 AM Dammm, that shite is low, looks sweet.
klepto 03-29-2008, 11:45 AM thanks to all for the complements...
1. rims in due time im thinking late april maybe may
2. ride quality as stated by my boy chrism is really good. i dont know how the teins feel but according to the research i did the teins are a tad bit less stiff compared to these. i love the ride.
3. BQE, lol....i dont think im driving on that shit any more probably, lol
4. my big test was last night through mid town and survive no scrapes or bottoming out - YAY
HCTR154 03-29-2008, 02:01 PM Looks good, Klepto. Personally, I think lowering springs are the FIRST thing one should do to an otherwise stock RX 8. Just my opinion...
CSISON 03-29-2008, 02:23 PM Lookin' real good, Klepto. Can't wait to see it with new rims!
XDEEDUBBX 03-29-2008, 02:45 PM i hope the front settles alilmorebut i doubt it will even up with the rear...very common amongst "lowering springs"
shaunv74 03-29-2008, 07:15 PM Hey guys. Looks good. A word of caution with the Espelir springs. I found that when I swapped to the lower pressure Koni shocks with my Espelir springs they couldn't support the weight of the car on their own in the rear and are compressed so much at rest that the first 1/3 of the spring coils are touching. It makes for a rough ride and then the coils bind under hard maneuvering. Take a look at my thread linked in my sig. and then I'd recommend taking a peak at your rear springs and see if they are compressed like mine are.
If not that's great but if so you should be aware that it may cause a bumpier ride and not be desireable if you track it.:(
SayNoToPistons 03-29-2008, 07:34 PM thanks to all for the complements...
Yeah, BQE is a wreck. They try fixing it but they fail every time. What a trainwreck that road is :( . How does the ride quality compare to stock especially around NYC?
PhotoMunkey 03-29-2008, 07:53 PM Shocks control ride quality, not springs. Stock shocks = stock ride, even on lowered aftermarket springs.
Spring rate, however, controls "ride frequency", or in other words, the rate in cycles per second at which the spring wants to rebound and contract. If the spring rate is too high for the shocks to control (dampen) then the car looks bouncy-bouncy on the freeway dips and heaves. It can also be dangerous in at-the-limit turns.
Race cars can run a ride frequency of 2.5 to 3 cycles per second, on ultra smooth racetracks. Street cars are comfortable between 1.2 and 1.8 cycles per second. A "sporty" spring for a street car typically falls between 1.8 and 2.2 cycles per second, depending on whether it will work on the stock shocks or requires aftermarket (stiffer) shocks.
And those Evo-R sway bar endlinks...? HAhahahahahahahahahaha! Don't get me started on the "Your swaybar is not in the correct position." statement! ROFL. As long as the sway bar isn't preloaded with tension, it'll be fine with the stock endlinks. The pickup point for the endlinks is approximately 50% of the control arm length, so take whatever the drop is (in this case about 1.5") and divide it in half, and that's the change at the sway bar. Since both sides drop equally, the bar simply rotates in its two mounts. Problem solved! :)
snipaz2420 03-29-2008, 07:55 PM lookin good as always man. o yea and happy bday :jump:
Razz1 03-30-2008, 02:08 AM Looks good!
Did you guys pre-load the springs?! :D:
chrism 03-30-2008, 08:58 AM the mechanic did it not us
did you do an allignment after?
Raptor2k 03-30-2008, 01:11 PM Chrism....check your PMs...urgent.
SayNoToPistons 03-30-2008, 02:30 PM Shocks control ride quality, not springs. Stock shocks = stock ride, even on lowered aftermarket springs.
Ahh...Thanks for the info!
klepto 03-31-2008, 12:14 AM im getting my alignment done this week once the springs settle completely
klepto 03-31-2008, 12:42 AM lookin good as always man. o yea and happy bday :jump:
thanks bro...
