View Full Version : BigRed's 8 Dynoed
BigRed 03-26-2008, 01:56 PM Here it is:
http://www.youtube.com/watch?v=unt7PNNGvEM
175.5 HP
BTW, does anyone know if there is something that doesnt allow dynos to calculate torque for rotaries unless you have a special tool? Not sure they were right, but the dynoes were cheap; they were only 30$ for 2 pulls. :rock: :rock: :rock:
Bastage 03-26-2008, 02:04 PM Here it is:
175.5 HP
Did the dyno shop tell you this? :Eyecrazy:
BTW if you want to measure torque for a given horsepower/RPM:
Torque = (Horsepower * 5252)/(RPM)
so if they gave you a HP curve, you can generate the torque curve that way.
trancesimulator 03-26-2008, 02:10 PM i only got 179.9 with just my sr motorsports pulleys when i did my runs.....i yet to do it since i dont my other stuff
CompMan 03-26-2008, 02:22 PM I thought its 180 stock?
dozer 03-26-2008, 02:25 PM ^if your lucky...
DOMINION 03-26-2008, 02:38 PM lol yup but on the other hand if you have some mods :smoker:
TopGear8 03-26-2008, 02:41 PM I would like to get my car on a dyno sometime soon.
mysql 03-26-2008, 02:46 PM rpm pickup can sometimes be tricky. if they don't pick up the rpm, you aren't going to get a torque number.
imput1234 03-26-2008, 03:12 PM Here it is:
175.5 HP
You have a MT right? No way is that right. check your coils
What dyno was it? I think in a socal dyno thread a while back deedub had the hks intake +exhaust and dynoed ~190ish
fahrfegneugen 03-26-2008, 03:21 PM That is news to me that the car doesn't produce near what mazda rates it at. Or do they just measure at a different point on the drivetrain? I guess I will do some reading...
Nice video
nvm I figured it out.
RWatters 03-26-2008, 03:32 PM Numbers will vary on each and every dyno because variables like calibration, weather, D/A, etc. have to be put into the calcuations. As a result of this a dynograph should be used as a base method for tuning and, IMO, nothing more. You could go to another dyno shop in town and make 10hp more, or maybe even put down 5hp less.
Cars that are coil-pack-equipped like the RX-8 can be sometimes hard to pick up an RPM reading on when they hook everything up. Like said if they have problems picking up RPMs you won't be able to get a torque calculation.
Also, the RX-8 is severely overrated as far as the horsepower number goes IMO. If you get 200-215 crank horsepower (180-190whp) out of your car in stock form I think you're sitting pretty good.
Lastly, track times tell the truth on your horsepower numbers a lot better than a dyno will. The dyno calibrations can be changed to make your car have 300hp if they wanted to. The track, on the other hand, will not change them and will not lie.
Jedi54 03-26-2008, 03:48 PM dynojet I assume?
Here are the results of the DynoDay I hosted last year. (your number is a bit on the low end but it's probably within tolerance)
1. Peterisurhero: 200.60
2. Razz1: 198.440
3. NgoRX8: 196.840
4. Newcastle: 194.540
5. xdeedubbx: 190.890
6. Jedi54: 190.290
7. Cesaralaniz: 187.900
8. Rotary Rasp: 186.410
9. Sopheak: 186.280
10. Murix: 185.430
11. Kwescott: 184.810
12. Scremn8: 184.540
13. Wing5: 178.560
14. Bao0518: 176.680
15. RXOcho: 175.540
16. Snowfl8k: 174.920
Automatic RX-8’s
1. Brgreen: 149.280
2. Jordanjerone: 145.040
BigRed 03-26-2008, 03:58 PM yes it is a mt, yes it was a dynojet. They said that it was 165 "SAE" corrected. It was a colder day... Anything that I should check? I mean, the car still runs like it came from the dealership :)
imput1234 03-26-2008, 04:00 PM yes it is a mt, yes it was a dynojet. They said that it was 165 "SAE" corrected. It was a colder day... Anything that I should check? I mean, the car still runs like it came from the dealership :)
Check the coils & plugs.
mysql 03-26-2008, 04:00 PM engine compression
Jedi54 03-26-2008, 04:00 PM check plugs and coils when you get a chance.
BigRed 03-26-2008, 04:03 PM i mean, the only place that i know of to check this stuff would be at the stealership. It is under warranty, and they have seen my mods before. they didnt really care...
Jedi54 03-26-2008, 04:04 PM plugs and coils you can easily check yourself.
BigRed 03-26-2008, 04:08 PM ^lol. okay then :) What is the easiest way? --- newbie question :)
Jedi54 03-26-2008, 04:22 PM plugs are easy.
- jack up the front left side of car
- insert jack stand
- remove wheel (loosen lugs BEFORE lifting car. ;) )
- straight ahead are the plugs.
- Brown is okay, black and white spots are bad.
If you've got more then 25,000 - 30,000 miles on those plugs, might not be a bad idea to just swap them out.
Here's how to check the coils:
http://www.finishlineperformance.com/pdf/rx8/bulletin/01-016-07-1793.pdf
JTtheDude 03-26-2008, 04:33 PM Did you do this at Rotary Performance in Garland or did you use another shop?
fahrfegneugen 03-26-2008, 04:42 PM The plugs are easy to get to get to on this car, they are out in the open and are right down where the oil dip stick is on the driver side.
imput1234 03-26-2008, 04:44 PM You'll need a sparkplug socket as well. I assume you probably don't have one.
This is the one I use: cheapest I found and comes with other sizes:
http://www.harborfreight.com/cpi/ctaf/Category.taf?CategoryID=156&pricetype=
fahrfegneugen 03-26-2008, 04:46 PM You'll need a sparkplug socket as well. I assume you probably don't have one.
They are useful on the lawnmower too:)
BigRed 03-26-2008, 07:11 PM my car only has 10k miles... Not a good sign :(
Jedi54 03-26-2008, 07:24 PM what year? It's possible the plugs just got fouled up on a cold start.
BigRed 03-26-2008, 07:36 PM 2006. also, the car was dynoed at Corvettes of Dallas. My family friend bought it so I kind of have a connection there.... :). I do need to check my plugs then, eh? What do you mean by them being colored brown, where would they be brown?
Jedi54 03-26-2008, 07:41 PM because that's what spark plugs do
BigRed 03-26-2008, 07:49 PM because that's what spark plugs do
wait, we were just talking about plug wires, and now you are talking about spark plugs :lol2: :lol2: . What colors brown?
imput1234 03-26-2008, 07:50 PM my car only has 10k miles... Not a good sign :(
Mayabe, they faked the dyno. :yelrotflm
I bet you killed the plugs lol
BigRed 03-26-2008, 07:57 PM ^I am going to check it as soon as I get back from michigan this weekend hopefully... ^OK, the plug then :)
jones75254 03-26-2008, 07:58 PM yes it is a mt, yes it was a dynojet. They said that it was 165 "SAE" corrected. It was a colder day... Anything that I should check? I mean, the car still runs like it came from the dealership :)
Alex, ur doin pretty good at that range IMO. Like others have said, u could go to another dyno in a another part of town and be at 180hp maybe even 185. Whats important is how it feels, and obviously it still feels great, so....
I will be hoppin up on the rollers soon for a session testing out some flashes. My car "feels" as good as it ever has, so whether it puts down 170 or 190 on that particular day at that particular dyno doesnt really make a diff to me. Only differences im looking for is with the flashes:)
I recall you talkin about ur hookup with Porsche (used tire hookup), now ur in with the Vettes too? Big timer.
Stop over someday and i will show u how to check ur plugs n all that. It will be easy for you cuz you have skinny arms and a wing span like Shaq:)
imput1234 03-26-2008, 07:59 PM wait, we were just talking about plug wires, and now you are talking about spark plugs :lol2: :lol2: . What colors brown?
When you take the plug out, the side going inside the engine that tip will be brown.
BigRed 03-26-2008, 08:00 PM ^next meet ill bring my jack (that i got in january :); unfortanutely a necessary purchase) and well check it perhaps
cheeto 03-26-2008, 08:05 PM its all good. the conditions can vary which can make the hp vary. you have to look at altitude, humidity, temp, and oxygen content in the air.
jones75254 03-26-2008, 08:11 PM I have heard reports of 8's dyno'd at 165whp and the owners are none the wiser, stating the car feels as strong as ever, but i guess thats all relative.
cheeto 03-26-2008, 08:50 PM ^ exactly. just get it dynoed a couple times over the next couple weeks at different times and average the numbers. especially if you can do it for so cheap. also check the coils and plugs as previously stated
butt dynos still suck
Razz1 03-27-2008, 10:55 PM Thats pretty good. Now just pull the fuse the next time.
