Im throwing a CEL P0302
Old Mar 25, 2008 | 07:27 PM
sauceyI986's Avatar
Went to Auto Zone and had them check my check CEL, it wasnt on but when i wot the CEL starts blinking. The code P0302came up. and it says it is a misfire of some sort.
Old Mar 25, 2008 | 07:34 PM
Jon316G's Avatar
Grasshopper
Did you trying using the search and typing P0302? Much can be learned that way.
Old Mar 25, 2008 | 07:37 PM
Jon316G's Avatar
Grasshopper
Just did a quick search (as I suggested) and found a thread titled "Solved the P0302"
This one might be a good read for you.
Old Mar 25, 2008 | 07:52 PM
Check your plugs/coils and wires.....
Old Mar 25, 2008 | 08:06 PM
Nemesis8's Avatar
Bigus Rotus
Yep - P0302 Rear rotor misfire detected
Old Mar 25, 2008 | 09:28 PM
first-rotary04's Avatar
wankel? what's that?
I was having the same code after the dealer replacesd the coils and spark plugs but first it'd only start blinking @ 5k or 6k RPMS then remained on all the time. try to reset it with the brake pedal technique and didn't work so i disconnected the battery and never came back on.
is it right what i did? or should've i taken back to the dealer? it's under warranty anyway
Old Mar 25, 2008 | 09:34 PM
HiTMaNN's Avatar
RX-8s Official Cool Guy
You did good but FYI the Brake Pedal dance does not reset CEL codes it just resets the Eccentric Drive shaft.
Old Mar 25, 2008 | 10:21 PM
lilring's Avatar
Finally a MT
i just had that same one. the dealer just replaced my wires and it was all set to go
Old Mar 25, 2008 | 11:44 PM
Jon316G's Avatar
Grasshopper
The "brake pedal dance" resets the KAM which contains the sensor profiles. This will clear the CEL... but it will come back if the "issue" isn't corrected.
Old Mar 26, 2008 | 12:57 AM
sauceyI986's Avatar
yes i did the search after the fact
Old Mar 26, 2008 | 06:25 AM
RWatters's Avatar
If you're still getting blinking then they did not resolve the problem. The ECU is detecting a misfire in upper RPM's on your #2 rotor. The resolution is either the replacement of the spark plugs (the typical resolution) or the replacement of the coil packs.
I have had this problem all week and replaced my plugs last night. Sure enough the leading plug on my #2 rotor had NO electrode left! I replaced all 4 just for the hell of it and now the car is running like a champ. Took around an hour and a half to do I think, and I'm far from fast when working on my car.
As far as getting rid of the CEL goes, I just unhooked my negative battery cable whie working on the car. Leaving it unhooked for a while will reset the ECU and get rid of the CEL.
I'm not CEL-free and my car is running like a champ.
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
alming1132
Sep 30, 2015 11:30 AM
Evan Gray
Sep 26, 2015 12:30 PM
