icto0389
03-23-2008, 01:56 PM
Ok i have a problem, and its a very annoying one.
I bought a clutch/flywheel kit from ACT and put it in. don't ask me why i got the 6puck stage three, i should have stuck with the street slip st2.
Anyway it worked ok for about 2 months, great grab, fast response and then... i had problems. for 1 the clutch never disengages 100%, probably like 95%. Two, the clutch feels lazy (or master cylinder) and it takes a good second and a half to disengage so you can shift. In other words (any attempt to shift it quickly ends up with gear grinding or i just wont go into gear.) sometimes you can try all you want and i will just grind away until you go for a different gear all together (mean while i'm standing on the pedal and its right to the floor.) Also the clutch grabs AT the floor, you let off a pubic hair and its engaging.
You can imagine how frustrating this is when a prelude can beat you cause you cant shift.
Two things have been recommended thus far. 1: bleed the clutch (is see the bleeder right on the firewall, but is there a proper bleed procedure? i know some other cars require you to bleed from multiple locations? does anyone know, has anyone done this on their 8 before? 2: get a new master cylinder one that has full clutch movement at like 1/2 or 3/4 pedal depression.
What do you guys think??? Help me out, i want to enjoy driving it again. and i DONT wanna have to replace/rebuild my tranny (sure i got filings in there already, gotta get one of those magnetic oil plugs):banghead:
