View Full Version : Stock Cat Switch Ratio?
maxrx8
03-22-2008, 01:41 PM
Hey Guys,
I got my 8 back and thought that they were going to replace the cat after they thought that the cat was melted.
Apparently not.
On the work order it states:
Tested cat before repair switch ratio value 1.527. Performed repairs on line #2, Drove vehicle, 20+ miles to reset values. Cat switch ration now 1.197 Well within specs (spec below 4.5). Possible failure due to misfire and heat condition. Not failing at this time.
I think that they are getting these readings through the 02 sensor.
Am I going to have to get a new cat soon?
Car runs great, better than new. Sounds louder.
Any thoughts would be appreciated?
Bill
swoope
03-23-2008, 12:37 AM
you needed to get a look inside to answer that ? likely the cat has failed. you will get a code before to long..
beers :beer:
nycgps
03-23-2008, 12:41 AM
Stock cat cost over 1000 bux. maybe thats why Mazda does not want to change them anymore.
but it sounds like ur cat is about to go. they're just trying to push u away.
is Easy to kill cat converter. especially on this car. but I dont feel like getting arrested :P
maxrx8
03-23-2008, 02:25 AM
Could this be the smell that is in the cabin.
It's not gas or oil, it's something else?
I only smell it when the fan is turned to recirculate the cabin air.
I didn't smell it before.
Is the cat covered under the 6year/60,000 powertrain warranty, or is it seperate?
My service writer told me they were looking at the RB intake and were hinting that it could be the problem and I should replace the stock intake if I bring it in again.:uhh:
Bill
alz0rz
03-23-2008, 02:56 AM
Bill
atleast you're getting a heads-up regarding the intake and they are not being asses about it just yet.. and i believe the cat is under the 100k emissions warranty?
maxrx8
03-23-2008, 03:09 AM
I've been reading up on the Magnuson Moss Act.
I didn't ever think I would have to pull it out.
I've had the Revi for at least three years and they have completed many repairs. And recalls. Even the latest with the misfire and all of this that led up to the cat being burned.
Won't this work in my favor?
Bill
Rote8
03-23-2008, 03:56 PM
Hey Guys,
Apparently not.
Bill
So they gave your cat it's shots and said "See you next year", sounds like my Vet.... :lol2:
Norm
chancejat
03-23-2008, 04:02 PM
Bill
i dont have a cat and to get rid of the smell at stop i turn on recirc on my ac...should work the same with your so ...your smell may be tranny oil slipping through the shift boot does it smell kinda like burnt rubber?
maxrx8
03-23-2008, 04:33 PM
Hey Chance,
When you think about it yes it does.
Not as sickning, but the smell is there.
They did the whole engine mount thing and all all of the fluids, tranny incl.
Could it be something they missed or does it just need to be burnt off?
Max
chancejat
03-23-2008, 04:40 PM
the smell could be a lot of stuff....any fluid thats sittling on the engine etc......if you think you cat is going just wait for the cel....it will come, then take it to mazda....your cat is actually covered for 80,000 miles via Federal Emissions Law for cars built after 1995
maxrx8
03-23-2008, 06:10 PM
Thanks.
