BOV Recirculation tube size?
Old Mar 21, 2008 | 03:16 PM
Grouch's Avatar
How important is the size of the recirculation tube important when recirculating a blow off valve? I noticed that i could get three different sizes:
http://www.hksusa.com/products/?id=798
And was wondering if there was a specific application for each size, such as maybe needing a size dependant on how much air gets blown off. Thanks.
Old Mar 21, 2008 | 03:47 PM
MazdaManiac's Avatar
get it as large as practical.
Old Mar 21, 2008 | 04:04 PM
ChattyRX8's Avatar
Now turbo!
Can you elaborate more on this? I'm stuck on this too, but with a GReddy RS BOV.
Does the practicality depend on how much boost is being run?
Old Mar 21, 2008 | 04:34 PM
Grouch's Avatar
I guess as large as it is practical depending on how much room we have under the hood, the hose sizes we can get and the location after the MAF where we weld on the inlet nipple and what size we can fit in that spot.
Old Mar 21, 2008 | 04:38 PM
MazsportScott's Avatar
Mazsport.net
You are running a map based system (Interceptor-X) so the normal MAF/BOV issues won't be a problem and you won't need to recirculate.
Old Mar 21, 2008 | 04:41 PM
mysql's Avatar
Doppelgänger
large as you can go. I'm using a 3/4" (19mm) bung on intake tube without issues at 10 psi right now.
Old Mar 21, 2008 | 05:31 PM
Most of these folks are switching to a MAF-based system.
Old Mar 21, 2008 | 06:31 PM
turborx8's Avatar
Boost 4 Life
SWEET!
I ordered the 19mm bov recirc attachment for my greddy type-rs bov last week.
Old Mar 21, 2008 | 06:45 PM
mysql's Avatar
Doppelgänger
yeah, my recirculate fitting is 19mm because I had the type-s recirculate fitting from over a year ago. The synchronic bov has a 1 1/4" sized tube, but I do not want to pull the intake pipe and get something new welded on so I used what I had, and it seems to work fine.
Old Mar 23, 2008 | 05:44 PM
turborx8's Avatar
Boost 4 Life
Here's a question; wouldn't placing the MAF before the BOV render the recirc vs. vent-to-atmo concern a simple sound issue or am I forgetting something?
Bump
I would like to know this also.
Old Mar 23, 2008 | 05:47 PM
mysql's Avatar
Doppelgänger
i don't understand the question. for most people, the maf is on the non compressed side, then after the maf is the turbo, intercooler, then the bov (compressed). anytime the bov goes off, there is unmetered air loss, so we get a temporary rich situation.
Old Mar 23, 2008 | 05:53 PM
mysql's Avatar
Doppelgänger
i did the boost only vacuum fitting on the sychronic bov today. that sucker works well.
without it, the bov releases air at -12 psi, with it enabled, it releases the air whenever boost isn't stable or building. so if i floor it at 7 psi and let off the throttle, it immediately releases the air while it's at 6 psi or so.
the net result of this is that the air is discharged back into the recirculate fitting and into the intake, the car doesn't have a "woosh" and jerk around, it just acts like a NA car when you let off the throttle.
I think I'll keep it setup this way from now on.
Old Mar 24, 2008 | 12:15 AM
ChattyRX8's Avatar
Now turbo!
This is good news for 2 reasons:
1. I don't want to spend $40 for a stupid fitting that probably cost $6 to make.
2. I like the whooshing sound!
Old Mar 24, 2008 | 01:32 PM
WinningBlueRX8's Avatar
FYI, I am a Synchronic dealer. Ask MM.
Yes it would, but I am not sure how well the RX-8 ECU will work on a "blow through" MAF setup. Everything I have heard says its pretty fickle.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
nferguson88
Oct 6, 2015 12:45 PM
GK1707
Sep 27, 2015 07:33 PM
