View Full Version : Problem with intercept X on Greddy turbo
qcheung
03-19-2008, 01:57 PM
Hey guy, i just finish installing a Greddy turbo and i have a tuned intercept X with it.....But i just won't let me start the car...does anyone know wat happen...and how can i fix it? because when i unplug the intercept X, the car starts right away with the OEM ECU.....
Please HELP
invasion08
03-19-2008, 02:39 PM
call scott at mazsport
x-attack
03-21-2008, 09:42 PM
Did you remove the one way check valve that is right after your throttle bottle body where you took your vacuum signal for the int-x and all your other components (BOV, Boost gauge)? i believe its green and white!!
mysql
03-21-2008, 09:44 PM
make sure the power cable for the int-x has the fuse properly installed and that it isn't blown.
StealthTL
03-21-2008, 09:59 PM
Mysql seems to be right - do the Int-X LEDs light?
S
qcheung
03-23-2008, 12:36 AM
Yes, the light did came on....
kersh4w
03-23-2008, 10:03 AM
the fuse is blown. joo need another. possibly 2. so you can see if it happens again, and then try to diagnose the problem. then try again. maybe 3. :P
dannobre
03-23-2008, 10:23 AM
Does it turn over?? Do you have upgraded injectors?? Do ou have it hooked up correctly? You need a Vac/boost signal to the unit for it to work.......start at the beginning and think through the whole install.
After that........is it flooded ( likely)
If it still doesn't start...give us a bit more information...
Im_DANomite
03-23-2008, 10:27 AM
i had the same problem when i had the Int-X. it would start with the OE PCM but not with the Int-X hooked up. make sure you have the right map loaded up.
i got the AP over the Int-X and it's awesome...
