Clicking sound on Greddy suspension??
Old Mar 14, 2008 | 12:10 AM
maxfoong's Avatar
Hi Guys, I always hear clicking sound on my suspension, i suppose? Is it normal? And when i tap my brake gently, some times also got clicking sound or tapping sound. And its on off? How??
Old Mar 14, 2008 | 12:18 AM
Spinning Sushi's Avatar
I <3 Sushi
It's a bomb!
Old Mar 14, 2008 | 12:32 AM
maxfoong's Avatar
Originally Posted by Renesis SE3P
It's a bomb!
That was helpful
Old Mar 14, 2008 | 12:37 AM
I <3 Sushi
Brakes make a rhythmic scraping noise at low speeds:
As you step on the brake pedal to stop while moving at low speeds, you notice a rhythmic scraping noise. As the car slows, the frequency of the noise also slows. The noise doesn't seem to be there when braking from high speeds. Sometimes the noise is more noticeable than at other times. The problem usually occurs suddenly.
Possible causes:
1. Your brake rotor is badly warped: Machine or replace brake rotors.
2. Your front wheel bearings are badly out of adjustment: Adjust or replace wheel bearings as required.
I hope this helps.
Old Mar 14, 2008 | 12:42 AM
maxfoong's Avatar
Possible causes:
I hope this helps.
Wow bro. Thanks a lot. I just bought a new rotor. About the bearings need to check it out. Anyway thanks again??
Old Mar 14, 2008 | 12:44 AM
I <3 Sushi
No problem. It could also be a bomb.
Old Mar 14, 2008 | 12:49 AM
I <3 Sushi
Also, the bearings rarely go bad on our cars so it's more than likely the rotors making the clicking noise. Replace your rotors first (considering how you already bought rotors) and see if you still get the clicking noise, if you do then it'll be the bearings.
Old Mar 14, 2008 | 01:14 AM
Swerve76's Avatar
Its prob that Mas Salamat guy hiding in ur boot! Quick call police!!! Got 50k reward money man...would be a nice sum to put down as deposit for GTR....
Old Mar 14, 2008 | 01:15 AM
I <3 Sushi
LOL! A bomb technician comes in right when I said "BOMB."
I <3 your avatar!
Old Mar 14, 2008 | 01:19 AM
Swerve76's Avatar
I <3 your avatar!
Ur avatar is pretty cool too dude
Old Mar 14, 2008 | 01:27 AM
coupe07's Avatar
SC 300HP!!
ur rotors are slotted... sure got tapping sound....
Old Mar 14, 2008 | 01:29 AM
maxfoong's Avatar
They say its the line on the rotor brake making the sound?
Old Mar 14, 2008 | 01:31 AM
I <3 Sushi
What rotors are you using? Stock or aftermarket? If it's aftermarket and it's slotted then it can also be due to the slots and/or uneven wear.
Old Mar 14, 2008 | 01:41 AM
maxfoong's Avatar
Project mu. Anyway, my next question is going to be tough to understand I notice that the lines on my left and right side are not coherent??
Should they be coherent??
Old Mar 14, 2008 | 01:42 AM
maxfoong's Avatar
Okay bro . Sorry Im a layman on technical issues, just to ocnfirm slotted means got lines on the rotor right. If thats true, mine is slotted.
Old Mar 14, 2008 | 01:47 AM
I <3 Sushi
They don't have to be coherent and yes, slotted means they have lines embedded into the rotors so that it can cool down faster.
This is what slotted looks like, there's lines in the the rotors:
Sometimes, not all the time, slotted rotors will make a clicking sound.
Old Mar 14, 2008 | 01:48 AM
I <3 Sushi
Also, are your rotors facing the right way? Sometimes people install them backwards and that causes alot of ticking noises. Can you take a picture and post it here?
Old Mar 14, 2008 | 01:49 AM
maxfoong's Avatar
Wow . Thank you all so much. I am such an amateur. Bro thanks for understanding my loose term as coherent. Cos the more worried I get, the more weird things surface. Lol.
Old Mar 14, 2008 | 01:51 AM
maxfoong's Avatar
Hmmm
the green should be outside right? If it is, then its correct. Lol Im not IT savvy also. Lol. How to post pictures??
Old Mar 14, 2008 | 01:56 AM
I <3 Sushi
Make sure the slots are facing the right way. Here's a masterpiece I just made in MSPaint.
That's how it should look like with the car facing to the right.
It depends, it doesn't mean that it's installed correctly when the green is facing out. You might have the passenger rotor on the driver side of the car accidentally and vice versa. I hope this helps.
Old Mar 14, 2008 | 02:00 AM
maxfoong's Avatar
On both side yeah looks the same??
Old Mar 14, 2008 | 02:02 AM
I <3 Sushi
Hmmmm... then the clicking is probably fine.
It is not rare to have aftermarket brake systems clicking. Your Greddy suspension is 100% fine, nothing is wrong with it. The sound is coming from your brakes.
I also had this problem on my RX-7 a long time ago but it went away after I put about 500 miles on the rotors.
Old Mar 14, 2008 | 02:08 AM
maxfoong's Avatar
I see
Thanks again everyone. I feel good.
Old Mar 14, 2008 | 02:11 AM
I <3 Sushi
No problem.
Old Mar 14, 2008 | 02:22 AM
maxfoong's Avatar
No problem.
Bro u sound like a mechanic. That ur profession.
