need some help - Question for Sandwich plate and water sensor adapter ?
Old Mar 13, 2008 | 07:54 AM
rotalution's Avatar
Hey guys ~
After doing some research on the Internet and the forum I just want to know and confirm rather the following is whats needed for oil pressure / temp + water temp
M20x1.5 thread size sandwich plate, but what O ring size ? and I also heard we need a thin type sandwich plate as our oil filter location is tight to squeeze another thing in that will lift the filter up more pushing against the firewall.. anyway.. anyone that knows the exact specification of the sandwich plate that would be great.... also pls dont direct me to the RB one.. as I need to get one very soon.. so cant wait for freight T_T
Water sensor adapter.. as far as I know... our hose is 34mm ? if anyone can confirm this.. that would be great.. thanks ~
regards
Old Mar 13, 2008 | 09:12 AM
staticlag's Avatar
The Professor
Originally Posted by rotalution
Hey guys ~
regards
Racing beat will ship next day if you call them for your order.
Old Mar 13, 2008 | 09:16 AM
Yes. M20xP1.5 For the Oil filter sandwich
For the water adapter, I think is 34mm not 100% sure. I have 1 installed but I cant find my receipt atm.
Oh for the oil filter adapter, if you're talking about Greddy universial one. you should use the *shorter* head instead of the longer one. You'll know what I mean. If you use the longer one you're going to get some stupid leak.
Old Mar 13, 2008 | 09:17 AM
Melbourne ...
I think he wants to get it locally.
Old Mar 13, 2008 | 11:09 AM
rotalution's Avatar
thanks for the reply guys but for the sandwich plate does that M20xP1.5 thread size already include / mention the O ring size ?
TYPE O-RING CENTOR BOLT PITCH SENSOR LOCATION PRICE CODE
Standard Type ×2  56φ/65φ 3/4-16UNF、M20×P1.5 1/8PT×2  M12×P1.25×1 ¥6,800
E Type  ×2  72φ/76φ M24×P1.5 1/8PT×3  M12×P1.25×1 ¥8,600 12002736
F Type  ×2  72φ/76φ M26×P1.5 1/8PT×3  M12×P1.25×1 ¥8,600 12002737
G Type  ×2  72φ/76φ 1-12UNF 1/8PT×3  M12×P1.25×1 ¥8,600 12002738
For FD3S Type ONLY 60φ×2   ※1 1/8PT×2  Plug bolts included ¥6,800 12044000
looking at that .. does that mean M20 x P1.5 = 65 mm O ring size.. ?
Old Mar 13, 2008 | 01:13 PM
staticlag's Avatar
The Professor
Originally Posted by nycgps
Melbourne ...
Ah, good call, I didn't see that.
Old Mar 13, 2008 | 03:19 PM
You're talking about Greddy/Trust right ?
Im 99% sure you can use the FD type filter. I never tried it myself but as far as I know all 13B engines use the same oil filter size. and the oil filter location is the same (Firewall is a bit different, but there shouldnt be a fitting problem.)
The Universal one comes with 2 oil filter bot and 2 O-rings. You can just use the smaller o ring with the short Bolt then it should not leak.
I switched to Anniversary because I think I accidently Broke the O-ring and I cant get a replacement ...
Old May 13, 2023 | 09:52 AM
Tomo's Avatar
Digging up an old thread but I would like to know more about this filter pushing against firewall:
Does this mean I can't use the 28mm/1.1inch adapter with the original oil filter?
What are the maximum dimensions of the sandwich plate and filter? (RX-8 2006)
Killawatts
Oct 22, 2021 04:09 AM
jpo
Feb 23, 2018 03:22 PM
PRL 84U
Feb 19, 2013 12:22 PM
sebbanboy14
Oct 7, 2011 11:01 AM
BigOLundh
19
Jan 2, 2007 03:39 PM
