Questions I have
Old Mar 12, 2008 | 11:06 AM
phildill's Avatar
Questions I have
Hi everyone. My name is Phil and I bought a 2004 RX-8 about a month ago. I love it but I have some questions.
1) Can i buy a switchblade key for my car and get it programmed?
2) What type of oil do you guys use with ur RX-8
3) How often do you add oil to your car
Old Mar 12, 2008 | 11:12 AM
CyberPitz's Avatar
Huge hole is huge
1.) https://www.rx8club.com/showthread.p...ht=switchblade
2.) People use 5w20 and 5w30 mostly, it seems. People will swear by the gods on each, so it's really up to you.
3.) It's good to check the oil every fill up or every other, depends on how spirited you drive the car, as the more you floor it, the more oil that gets deposited into the rotor housing. Just check, and when you're low, add up.
Old Mar 12, 2008 | 11:30 AM
Tim Tim Tim's Avatar
auto suckkssssss
yes you can do a switchbade key
I used 5w-30 but it really desnt matter
usually once every few weeks. My fiance drives it and only works 2 miles away so its not beat on alot or driven very far.
JRichter's Avatar
Void Where Prohibited
Hello and welcome.
1.) yes
2.) 5w20
3.) Yeah, check oil every other fillup to be sure. It seems lately I usually add a half-whole quart about every 1000-1500 miles or so.
Old Mar 12, 2008 | 12:40 PM
jdoo's Avatar
1. yes
2. 5w20 but based on the findings in the "lets look at expo1's 100k motor" thread I think i'll probably switch to 5w30.
3. Used to check it every fill up but it goes down SLOW. Now I check every 3 fillups and just add more when it gets to the 3/4 mark on the dipstick.
:edit: Here's the post I was talking about https://www.rx8club.com/showpost.php...&postcount=190
Old Mar 12, 2008 | 01:17 PM
rglbegl's Avatar
Baned
1) yes
2) 5w20
3) check it every fill up. Actually AD oil about every 1000 miles (half quart or so)
Old Mar 12, 2008 | 01:24 PM
1. yes
2. 5w20 Castrol GTX
3. I check it every weekend after I wash my car.
Old Mar 12, 2008 | 01:25 PM
chrism's Avatar
Misfit Moderator TnC
1-yes
2-5w20 Castrol GTX
3-every 1-1500 miles
Old Mar 12, 2008 | 01:26 PM
Smoke Honda's Avatar
Mid-Boss
Put this on and follow me!
Old Mar 12, 2008 | 01:28 PM
alnielsen's Avatar
I had one of those switchblade keys for a rental car. I hated it. It kept coming open in my pocket and then it would be difficult to get out of my pants.
I wouldn't want one.
Old Mar 12, 2008 | 02:30 PM
JRichter's Avatar
Jeans too tight?
I've never had that problem with my Mazda one. It lock's tight and the button requires a bit of pressure to release even after 3 years and countless people playing with it.
Old Mar 12, 2008 | 02:47 PM
Dive Bum's Avatar
IYAOYAS
1. yes
2. 5w-30 Castrol
3. At least twice a month... I fill up once a week.
As per the owners manual: "Mazda recommends checking the oil level at every second fuel filling. The oil consumption of the engine depends on engine speed and engine load. Under extreme driving conditions, oil consumption can be higher."....
"Use SAE 5W-20 engine oil. Oil container labels provide important information. A chief contribution this type of oil makes to fuel economy is reducing the amount of fuel necessary to overcome engine friction. Only use oils “Certified For Gasoline Engines” by the American Petroleum Institute (API). An oil with this trademark symbol conforms to the current engine and emission system protection standards and fuel economy requirements of the International Lubricant Standardization and Approval Committee (ILSAC), comprised of U.S. and Japanese automobile manufacturers."
Old Mar 12, 2008 | 06:48 PM
whitebeau's Avatar
Touge Chaser
1. yes
2. 5w-20 Royal Purple
3. Once a Week. Or every 5 business days, Holidays excluded.
Old Mar 12, 2008 | 11:35 PM
Originally Posted by chrism
1-yes
2-5w20 Castrol GTX
me too, but I usually change it before 1500 miles.
Old Mar 19, 2008 | 09:30 AM
phildill's Avatar
A Switchblade Key
So I just bought a switchblade key, if I want to get it programmed should i go to a dealership to get it cut too, or can i get it cut at Wal-mart. I don't want to mess up my car or the key, so the safest way would be the best for me. Thx
Old Mar 19, 2008 | 09:34 AM
StealthTL's Avatar
Metatron
Walmart (locally) checks the key with a scanner, and if it has an immobilizer chip in it they refuse to cut it. Probably don't want to refund you for a $40 blank if they screw up.
Locksmiths can do it, then just follow the priogramming thread in the DIY section, save yourself $100 dealerbucks!
Old Mar 19, 2008 | 10:15 AM
JRichter's Avatar
Based on pass experience, I wouldn't trust Wal-mart unless you've got spares. I've very rarely had them cut the key correct the first time and you've only got one chance.
Old Mar 19, 2008 | 10:16 AM
1. Yes, you can buy it and do it yourself. but the first requirement is that you'll need 2 *already* working keys.
2. I used to use 5w30 Royal Purple Full Synthetic, but I just switched to 0w30 "true" Castrol Syntec Full Synthetic cuz it was on sale, as soon as my *supply* runs out, maybe till the year end , I will start using Redline 5w40.
3. Close to never, Cuz every oil change I top it off to the Max level, then I just drive 1500 miles - 2000 miles and I'll change it out and do the same thing
Do what Stealth suggested (locksmith)
Old Mar 19, 2008 | 02:52 PM
fahrfegneugen's Avatar
If you go to the dealer to get the new key, they are going to charge you up the wazzu. I paid unfortunately $160 for a key copy and a newly programed fob.
Enjoy the car
Evan Gray
Nov 24, 2015 01:00 AM
nferguson88
Oct 6, 2015 12:45 PM
urbanvoodoo
Sep 30, 2015 12:41 AM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
