RX8 won't start....
Old Mar 11, 2008 | 03:18 PM
bnstreet's Avatar
RX8 won't start....
My poor RX8 has been sitting out all winter, only getting started periodically, and for some reason now it won't start. It turns over, i cleaned the plugs, i put the timing light on it to see if there were any pulses, which there was, and it's getting fuel, how much i don't know, but it's there. It also makes this strange clickinh sound after the fuel pump shuts off under the hood. I was unable to retrieve any DTC's from it as well. Does anyone out there have any ideas? Thanks guys!
Old Mar 11, 2008 | 03:37 PM
Soapflake's Avatar
You try adding fresh gas?
Old Mar 11, 2008 | 04:40 PM
endowdly's Avatar
Guppies? Anyone?
I agree. Flush the gas lines, change the filter, put in new gas and new sparks. Yeah?
Old Mar 11, 2008 | 04:42 PM
endowdly's Avatar
Guppies? Anyone?
PS if it gets super cold during your winter, gas might have frozen somewhere on your lines. You should check your tanks and lines for the too.
Old Mar 11, 2008 | 05:34 PM
Nopstnz's Avatar
dead battery?
Old Mar 11, 2008 | 05:55 PM
Weak battery or bad starter or flooded
Old Mar 11, 2008 | 06:03 PM
clmantis21's Avatar
im guessing flooded as well. Have you tried push/pull starting it?
Old Mar 11, 2008 | 07:47 PM
endowdly's Avatar
Guppies? Anyone?
if you started it in the middle of winter periodically and didn't rev it or give it enough time to warm up, it is probably flooded. they flood much easier when cold.
Old Mar 12, 2008 | 04:10 PM
bnstreet's Avatar
I thought my line or tank was frozen but i pulled it into the heated garage and let it warm upfor about a week and added ISOheet and fresh gas to remove water or unfreeze it, still nothing. the starter whips it right around, my friend suggested maybe the walls have been washed down and need oiling for compression. the plugs have been cleaned and will get cleaned again if needed. The fuel filter would probably be a good idea to replace it. but other than that any other ideas? In the mean time i guess the minis will keep her warm...
Old Mar 12, 2008 | 04:13 PM
JRichter's Avatar
Void Where Prohibited
Maybe it could still be flooded? Do you smell excessive gas when starting?
What year and how many miles?
Ajmurphy85
Jul 30, 2015 07:51 AM
Davey's RX-8
Jul 28, 2015 12:13 PM
harithac
Jul 25, 2015 04:21 PM
Jvswan
28
Jul 23, 2015 09:02 AM
Kangarhew
Jul 18, 2015 08:27 PM
