HELP: Rattle/creek from the front suspension.
Old Mar 10, 2008 | 09:04 PM
Interpol's Avatar
There is this rattle coming from the front suspension, mostly the right side. It happens whenever it goes over a bump. A speed bump is too large, more like a patched spot or crack in the road will do it. It also creeks on the right side when I jacked up my RX-8 to check it out.
I put the car up and took the front right wheel off and check that everything was tightened. I tightened the nuts on the thing the sway bar attaches to and the top one wouldn't tighten all the way. Not sure if it's supposed to be like that.
I have Tanabe Sustec Pro 5 coilovers with TEAS dampener controller, Tanabe Sustec Pro sway bars, and Greddy strut braces.
Any ideas as to what it is?
Old Mar 10, 2008 | 09:13 PM
expo1's Avatar
He's as bad as Can
You check the grease on the sway bars??
https://www.rx8club.com/series-i-trouble-shooting-95/something-owners-aftermarket-swaybars-might-want-lookout-65304/
Old Mar 10, 2008 | 09:14 PM
staticlag's Avatar
The Professor
sounds like the swaybar is loose, did you torque everything to spec?
If not I would buy a torque wrench, torque everything to spec and see what happens.
RXFEVER
Aug 29, 2018 10:14 AM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
RXFEVER
Sep 11, 2016 02:51 PM
Steve Dallas
Sep 19, 2015 09:39 AM
TheRedRotor
Sep 12, 2015 07:42 AM
