Clean up grease?!
Old Mar 8, 2008 | 12:15 PM
ChattyRX8's Avatar
Now turbo!
Clean up grease?!
Um, my dog found my old front sprocket cover from my motorcycle and dragged it into the house. I was working in the garage and had the door open so she could come in and out as she pleased. Now I have greasy puppy prints all over the carpet that I HAVE to clean before the wife gets home from work, or I am dead.
I've tried Shout and Dawn dish soap with hot water, but it's not working. I need ideas fast...
Old Mar 8, 2008 | 12:35 PM
HiTMaNN's Avatar
RX-8s Official Cool Guy
http://www.weardated.com/pages/warra...ove_guide.aspx
Old Mar 8, 2008 | 12:36 PM
HiTMaNN's Avatar
"Grease
REMOVAL PROCEDURE(S):
Remove as much foreign material as possible by blotting with a white paper towel or scraping with a dull knife. Apply isopropyl rubbing alcohol to a clean white cloth, white paper towel or cotton ball. If the spot extends deep into the pile, blot until it is removed or no color transfers to the cloth. Do not allow the alcohol to penetrate the backing, as it will destroy the latex bond. If the spot is on the surface only, rub in one direction at a time.
If rubbing removes the spot, blot dry and stack several white paper towels over the damp area. Place a brick or similarly weighted object on the towels to keep them in contact with the carpet. The towels will absorb any stain wicking up from the backing to the carpet surface. Allow carpet to dry, remove the brick and towels, and brush up the pile.
REMEMBER! Never us a circular motion to remove spot as this may destroy the texture.
If the spot is not completely removed, try the following.
Apply a small amount of a detergent solution to the spot (1/4 teaspoon detergent per 1 qt. of water) Blot with a white paper towel to work the detergent into the affected area. If the spot is being removed, continue applying detergent and blotting until spot is completely removed. Using a spray bottle, rinse with tap water, and then blot to remove excess moisture. Next, spray lightly with water, but instead of blotting, apply a pad of paper towels, weigh them down with a brick and allow to dry. If the stain remains, moisten the tufts in the stained area with 3 percent hydrogen peroxide and let stand for 1 hour. Blot and repeat until carpet is stain free. Because light will change peroxide back to water, no rinsing is necessary. Apply a pad of paper towels and weigh them down with a brick. Allow carpet to dry. Remove brick and towels and brush up the pile.
Some items to have available to remove spots
* White paper towels or white terry towels.
* Hand dish washing detergent that doesn't contain lanolin or bleach (such as Dawn® and Joy®). To make a detergent solution, mix 1/4 teaspoon of the detergent with 1 qt. of water.
* Spray bottle for applying detergents and special solutions.
* Household ammonia solution of 1 tablespoon of clear household ammonia per 1/2 cup of water.
* Isopropyl rubbing alcohol.
* 3% hydrogen peroxide.
* White vinegar solution made up of 1/3 cup of white vinegar, 2/3 cup of water.
* Spoon and dull knife.
* Brick and brick paver.
Dawn® and Joy® are registered trademarks of Procter and Gamble.
Stains that can not be removed
Acid toilet bowl cleaners, acne medication, alkaline drain cleaners, chlorinated bleaches, hair dyes, iodine, insecticides, mustard with tumeric, plant fertilizers and stains of this nature cannot be removed because they permanently alter the carpet's color. Call a professional. Typically, professionals address these types of stains by replacing the stained area. If you do not have extra carpet on hand, they might cut a piece from a closet, or some other inconspicuous area and insert it into the area where the spot was cut out."
Here is the direct link for taking out grease
Old Mar 10, 2008 | 01:04 AM
there's a carpet cleaner called "RESOLVE" sold at most stores that does a great job
Shankapotamus3
Mar 14, 2021 03:53 PM
MolecularConcept
11
Sep 29, 2015 09:21 PM
Jb4ker96
Sep 27, 2015 10:06 PM
drlubell
Sep 26, 2015 11:58 PM
