What does this light mean on my dash?
Old Mar 6, 2008 | 08:53 PM
darthanakin23's Avatar
O.K. I had the Mazda dealership install lowering Tanabe springs in my car and when i picked it up and drove it i noticed a light on thats right by the gas tank meter....It looks like a oval with a arrow next to it pointing up and a arrow pointing down...I told the dealership and in the manual its the symbol for the headlight adjustment option which i dont even have...lol
Now why is that light on if i dont even have the headlight adjustment option? I know its nothing to worry about since its not a CEL or any maintenance light, or is it something to worry about? What are your opinions?
Old Mar 6, 2008 | 09:08 PM
Just looked under my car on the drivers side and found something just hanging...It looks like its screwed in one end and then its a grey wire that just has a metal V attached to it...Is this the ground for my headlight adjustment? Even though i dont have the option on my car, could it be why the light is on? If so where do i screw in that V?
Old Mar 6, 2008 | 09:10 PM
you dont even know what your car came with.
Sell your car.
Old Mar 6, 2008 | 09:13 PM
Easy_E1's Avatar
Take it back to the dealer and tell them to fix it! With the quickness.
Tell the dealer,,,,"Who do you think your dealing with hear? PUNK! Fix the freeeeeeeking car!"
That should work.
Old Mar 6, 2008 | 09:21 PM
alnielsen's Avatar
Hey guys, take it easy on the Noobs.
There is a sensor on your rear end that determains how your headlights should be adjusted. It moves them up or down depending on how much weight is in the car. When they hooked up your bars, they must not of reconnected it or they broke it. Take it back to the dealer, that did the work, and have them fix it.
dillsrotary's Avatar
jersey fresh
serious answer: the headlight sensor is in the rear of the car.
Old Mar 6, 2008 | 09:25 PM
So is it that V shaped wire thats hanging there that is causing my light to come on? Also one last thing, i noticed that the front passenger side is like a quarter inch higher then the front driver side...is that a problem too? Tanabe told me that a quarter of a inch is acceptable...
Im not talking about the headlight sitting lower, im saying that after the springs were installed today that my passenger side front sits .25 (quarter of a inch) higher then the front driver side...I measured from the center of the rim to the bottom of the fender.
Old Mar 6, 2008 | 09:27 PM
GuyWithRx8's Avatar
Low compression
The passenger side headlight should be aimed higher than the driver's side, it's comes like that stock, I believe it's so you don't blind other motorists as much
Old Mar 6, 2008 | 09:34 PM
kevinD1226's Avatar
lets be serious here... that light means ur out of directional fluid..
im j/k man just take it to the dealer and have them fix it
Old Mar 6, 2008 | 09:36 PM
You need to measure it on a lift. A lift is completly flat.
Then measure the height from the lift to the bottom of the frame.
That is the correct way to measure the height.
I am going to do that in the morning, now how about the issue with my cars front passenger side sitting a quarter of a inch higher then my front drivers side? Is that a issue or normal? Just got them installed today, the lowering springs that is.
Old Mar 6, 2008 | 09:40 PM
^ Read what I posted.
1/4" is acceptable but you need to measure it correctly.
Old Mar 6, 2008 | 11:23 PM
I just got back from driving it a little bit and of course giving it its redline a day...and measured again and the gap between the driver front and passenger front is becoming smaller, so i think the spring thats on the passenger front is settling in...makes sense? Sorry if im being nooby, i came from a Subaru Sti 06 to this car, i would still have my STI if it wasnt for some drunk female totalling my car by rear ending me at 55mph....but i am really liking my RX8 though. :-D
Old Mar 7, 2008 | 01:02 PM
zoom44's Avatar
your still going to have the sensor fixed right?
Old Mar 7, 2008 | 03:32 PM
I just got home from the dealership and they checked out the sensor and said it had to be adjusted and now the light is off, so im good right? They said it wasnt unplugged and just needed adjusting, but i think they were trying to cover up there stupidity...So im fine now?
Old Mar 7, 2008 | 03:59 PM
Nubo's Avatar
Lubricious
Speak for yourself, buddy!
Old Mar 7, 2008 | 05:17 PM
Well thank you for calling me stupid....Seriously when i had my sti and was on subaru forums, there wasnt as many rude remarks as there are here, why call me stupid? Because I am new to rotaries and the RX8? Thanks again man, you made me night by calling me stupid...lol.
Old Mar 7, 2008 | 05:42 PM
savedsol's Avatar
Carbonormous
Do you have HID lamps in your headlights stock? Then you have the headlight adjustment. It's an auto adjustment - no interior switches.
Don't putz around getting these fixed. There are sensors on the drivers side front and rear wheels and the master is in the drivers side headlight. Each sensor is $500+ so don't delay addressing this problem. Also look on finishlineperformance.com there was a TSB for crappy headlight sensors that allowed water to get in them. Print it and bring it in if your VIN # is within the range listed.
Again, don't delay! Get the dealer to fix this ASAP!!! Call them right now to tell them.
Old Mar 7, 2008 | 05:43 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Yeah....you are okay now.
If you saw it hanging before, now go look without touching it and see if they just attached it or if it changed in any way. If it did..........then they lied and just covered there @ss. It's self adjusting, that's why it's there, so what did they adjust? They adusted plugging back in the friggin wire they knocked off.
Old Mar 7, 2008 | 05:45 PM
Well if before going to the dealer this morning that headlight adjustment light was on (on my dash) but now they said they fixed it by adjusting something and now the light isnt on, so if the light isnt on, am i not ok?
Old Mar 7, 2008 | 05:48 PM
Mazurfer's Avatar
Yes..............you are okay!
Old Mar 7, 2008 | 05:51 PM
I just talked to my tech at the dealer and he said the Rod on the back was pointing down, not up...that was the problem, does that make sense?
Old Mar 7, 2008 | 05:52 PM
alnielsen's Avatar
Just try to ignore the kids. They don't get out of the house too often and the don't know how to behave.
It makes sense if they forgot to reconnect it after they got done.
Old Mar 7, 2008 | 05:57 PM
shaunv74's Avatar
Power!!
Yes the springs will settle. Also your right heights won't all be exactly the same. In fact if you buy a set of height adjustable coilovers you'd intentionally have differences in height in order to corner balance the car and compensate for your weight in the drivers seat.
Short answer: It will settle over a week or two and a 1/4" is fine.
200.mph
Dec 10, 2018 03:49 PM
zoom44
General Automotive
Nov 16, 2015 11:38 PM
CARBONRX-8
Oct 5, 2015 03:46 PM
djp6783
Sep 19, 2015 12:12 PM
