I went over redline, am i in trouble?
Old Mar 3, 2008 | 12:59 AM
darthanakin23's Avatar
I was driving today and i punched it (floored it) in 1st gear and accidentally went to 9500 rpm's...i dropped it into neutral right away because i got scared for going that far, is that going to harm my engine or tranny or car in anyway? Thanks in advance for the replies...
Old Mar 3, 2008 | 01:12 AM
tiltmode43's Avatar
OMGITM!
Rev limiter is there for a reason
Also, the stock tach isn't 100% accurate
Old Mar 3, 2008 | 01:15 AM
HiTMaNN's Avatar
RX-8s Official Cool Guy
Isn't the rev limiter at 9300 RPMS?
Old Mar 3, 2008 | 01:20 AM
I have no idea but im pretty sure i didnt hit the rev limiter, i have a pretty loud exhaust and would hear the rev limiter yet, i would think...So going to approximately 9500 isnt harmful at all? I mean im not going to do it again, lol...It was accidental.
P.S. Where does the rev limiter hit?
P.S.S. Also since i still have my cat and resonator but have 3 inch pipe to a 2.5 inch Y pipe to exhaust tips (no mufflers), can i still shoot out fireballs? In between gears when im flooring it, i hear little baby backfires i think....
Old Mar 3, 2008 | 01:21 AM
trustbuddy's Avatar
your 8's fine.
Old Mar 3, 2008 | 01:23 AM
tiltmode43's Avatar
OMGITM!
I'm not 100% sure about the limiter, for some reason 9300 seemed familiar to me too but I'm not exactly sure. You should be fine
For future reference, your car will blink a check engine light if anything goes wrong
Old Mar 3, 2008 | 01:27 AM
Would the check engine light stay on, or just blink for a second? Also how about the backfiring (fireball) question...is it possible with my exhaust setup?
Thanks...
Old Mar 3, 2008 | 01:28 AM
tiltmode43's Avatar
OMGITM!
Is the true rev limiter at 9000 and our tach just reads ~9300? Makes sense to me
Old Mar 3, 2008 | 01:33 AM
tiltmode43's Avatar
OMGITM!
Don't know what exhaust setup you have To easily shoot fire you really need a straight pipe (no Catalytic converter) and have the Air Fuel Ration rich. Happens with consistent high RPMs (ie shift during heavy high rpm load, rev up high after high rpm driving, etc)
A quick blink can mean something such as a simple misfire. Solid light usually means its in the breathing of the engine and thus shouldn't be detrimental to your engine (depends, might kill your Cat). Constant blinking? Well, I've never been there before, my guess would be something very important going very wrong.
Stock some cars will shoot flames every once in a blue moon. Intake/Exhaust got me a bit more (may just have seemed like it). Straight pipe almost shoots too much, I'm scared to accelerate fast into traffic on the highway for fear of law enforcement.
Old Mar 3, 2008 | 01:51 AM
whitebeau's Avatar
Touge Chaser
Beeps at 8500, i've gone to 9200, it could be at 9300, or 9500. Some people have done a flash to bump up the limit to 10k.
This old thread lists 9500. I've bounced off it once or twice in a drift, but never looking down, hear the beep? get ready to shift up....
https://www.rx8club.com/series-i-tech-garage-22/does-rx-8-have-rev-limiter-17319/
Old Mar 3, 2008 | 02:18 AM
mmats69's Avatar
93.5 octane
fuel cut is at 9500. hit it by accident myself
Old Mar 3, 2008 | 02:23 AM
Brettus's Avatar
Boosted Kiwi
no - the rev limiter kicks in at 9000 (stock ) . The rev counter is 3-500 optimistic so you see 9300-9500 but are actually doing 9000 .
Also - the RB flash takes you to 9300 not 10000 . where did you hear 10k ?
Old Mar 3, 2008 | 02:27 AM
Brettus's Avatar
Boosted Kiwi
doing it in 1st gear can be a little hard on the box - especially if your shifting technique is not great . However the renesis will love you for hitting the red line as often as possible
Old Mar 3, 2008 | 02:34 AM
tiltmode43's Avatar
OMGITM!
Some previous info on the "race flash" led many to believe 10k
Old Mar 3, 2008 | 09:47 AM
Tim Tim Tim's Avatar
auto suckkssssss
basically what there saying is your car is fine. there is a rev limited which you will for sure hear with or without an exaust on your car. Even if you did hit that your car is still fine, just dont drive around bouncing on it.
Old Mar 3, 2008 | 12:36 PM
8 Maniac's Avatar
Senior Member
I dunno, I would buy a new engine if I were you.
Old Mar 3, 2008 | 01:28 PM
jones75254's Avatar
Ur fine. I went for a data logging session (with data tool hooked into obdII) the other day and purposefully went to around 9200-9300k rpm and when i analyzed the data i found that i actually only went up to like 8800k rpm's. The Tach is not entirely accurate....along lines of what Brettus cited above
8 Maniac, thats messed up dog
Old Mar 3, 2008 | 01:33 PM
Keyten's Avatar
From what I remember reading, and I could be wrong, but our engines can handle up to like 13k but the transmission can't. If anything you're hurting your transmission reving that high.
Old Mar 3, 2008 | 02:17 PM
04RX8man's Avatar
Rotary Powered Countryboy
rev limiter is between 9300 to 9500 hit it yesterday when passing a car......bounces back and forth between both lol.........ur motor is fine......as long as u don't do it constantly
Old Mar 3, 2008 | 02:21 PM
FloppinNachos's Avatar
i think past 11k the eccentric shaft starts to bend?
Old Mar 3, 2008 | 03:09 PM
Renesis07's Avatar
Vtak just kicked in yo!!
no, I do this at least twice a day
Old Mar 3, 2008 | 03:13 PM
delhi's Avatar
Grand Chancellor
its ok. But don't do it on any other engine say a VQ. It goes KABOOM!
Old Mar 3, 2008 | 03:18 PM
Renesis07's Avatar
wouldnt it be more like CLUNK CLUNK CLACK CLACK CLACK BOOOM......*tires screeching* BOOOM *into a guardrail*?
Old Mar 3, 2008 | 03:19 PM
deadphoenix52's Avatar
meh.
i try to red line it at least once every time i take it out. its good for it.
Old Mar 3, 2008 | 03:24 PM
Cattywampus's Avatar
Turbos blow!!
Not in my car. Mine will touch 10 in gear. It stops around 9k when in neutral.
