Car won't start. How do I know if it's flooded?
Old Mar 1, 2008 | 11:37 AM
turborx8's Avatar
Boost 4 Life
It cranks over and i can smell the gas.. it stumbles allot like it wants to start but no nice.
I ended up killing the battery trying to start it so I used my 600amp Eliminator PowerBox booster and I spent another 10mins trying to start it and nothing.
Is it flooded?
Old Mar 1, 2008 | 11:42 AM
JRichter's Avatar
Void Where Prohibited
Sounds like it. Try the deflooding procedure...
Old Mar 1, 2008 | 11:43 AM
JRichter's Avatar
https://www.rx8club.com/rx-8-discussion-3/yay-deflooded-8-all-myself-136789/
Old Mar 1, 2008 | 11:57 AM
turborx8's Avatar
Boost 4 Life
Originally Posted by JRichter
I just went out to try that.. no luck
Old Mar 1, 2008 | 12:12 PM
whitebeau's Avatar
Touge Chaser
yikes.. you did the oil into intake port de-flood?
Well, unless your plugs are completely fouled. it should start up with the powerbox to make sure it gets the rpm's needed to start up. have you gone 30k on these plugs? i'd try again pulling the injector fuse, so it cycles without pumping fuel (Dont pull the fuel pump relay). Try that twice, then put the fuse back in and try to start it up normally.
My guess is the plugs are soaked with fuel. the turnover with the gas pedal down is suppose to disable the fuel injector from spraying during turnover. But pulling the fuse will make sure.
Unless you have a dead coil, you might have to change the plugs.
best of luck
Old Mar 1, 2008 | 12:21 PM
pdxhak's Avatar
Official Post Whore
I did not read the link but did you do what the manual says? My wife flooded my car but I was able to start it. I hooked up jumper cables to her MDX and then followed the procedures in the manual. The only thing I did different was try to start the car for 20 seconds. Eventually it started and did not have to take it to the dealership.
Old Mar 1, 2008 | 12:29 PM
pdxhak's Avatar
Official Post Whore
Oh yeah one more thing I did different. After a few attempts to start the car with the peddle to the floor to not add any additional fuel, I cranked the motor with my foot off the peddle and it started.
Old Mar 1, 2008 | 03:40 PM
turborx8's Avatar
Boost 4 Life
Nothing I have read is working and I am starting to think my coils are finished.
They have been acting up since December so I ordered the Mazsport ignition solution and they still have not shipped them to me yet.
I can't even throw money at the problem to solve it.
Old Mar 1, 2008 | 04:28 PM
miker1's Avatar
no start
pull a spark plug and see if it is wet.the hook the plug back to its wire, move it away from the plug hole ground the body of the plug and see if you get a spark, then you may know what action to take.
Old Mar 1, 2008 | 04:56 PM
turborx8's Avatar
Boost 4 Life
Right now thats impossible. The car is stuck on the side of the road under 2ft of snow.
Old Mar 1, 2008 | 05:06 PM
whitebeau's Avatar
Touge Chaser
ahh Quebec Canada... i know i know.. what other Quebec is there sorry to here that man.
There is a TSB that gives a step by step walk through on how to test the coils with a volt meter. Instead of pulling the plugs, if you have an extra set of wires & spark plug, you can pull the main one off, and plug in a test/temp plug/wire set to 1 of them, and see if they all fire, and go to the next one until all 4 are tested....
That won't require getting underneath.
Old Mar 1, 2008 | 06:07 PM
yenphi's Avatar
I just got the same thing last week, car sit there for 3 days , I had tried everything here as I learn and read but no luck, then I push the car and it run again, so if it is manual and tried everything, push is the way to save money and time.
Old Mar 1, 2008 | 11:24 PM
m3pkrobert's Avatar
I Have The Same Damm Problem Right Now Its Suxs
Wantingtoknow
Dec 15, 2016 02:25 PM
Davey's RX-8
Jul 28, 2015 12:13 PM
harithac
Jul 25, 2015 04:21 PM
Bamaham
Jul 23, 2015 08:08 AM
thedragonrotar
Jul 22, 2015 08:46 PM
