MazSport Dual Resonator exhaust midpipe?
Old Mar 1, 2008 | 07:25 AM
Rote8's Avatar
Anyone running the Mazsport (CAT less/Dual resonators) midpipe?
Do you get CELs?
Old Mar 1, 2008 | 11:29 AM
snipaz2420's Avatar
the bukkake master!
there is a rather large thread on this but yes you will get cel because there is not cat converter
Old Mar 1, 2008 | 11:31 AM
mysql's Avatar
Doppelgänger
Do you get CELs?
The car has a sensor before and after the cat. If there is no cat the readings will be the same and it will set off a CEL since clearly the cat isn't functioning.
However, many of us with turbos and no cats do not get any CEL for missing cat. No idea why. Maybe the same will be true for you.
Regardless, if you get the cobb accessport you can delete any CEL you don't want, so ultimately it no longer matters if something produces a CEL.
Ovr-9000
Apr 7, 2016 11:19 PM
qtipconnoisseur
Oct 29, 2015 07:19 PM
yapakanichi
Sep 25, 2015 07:55 PM
