Wats a good flywheel/clutch combo
Old Feb 29, 2008 | 01:57 PM
Rx8urZ's Avatar
where can i get a nice street clutch and flywheel setup? i was thinking act flywheel and stage 2 clutch wat do you guys recommend
Old Feb 29, 2008 | 01:59 PM
check with Charles Hill, he's got something in the works for ya!
https://www.rx8club.com/series-i-major-horsepower-upgrades-93/bhrs-product-line-135070/
Old Feb 29, 2008 | 02:17 PM
mysql's Avatar
Doppelgänger
I bought the HD ACT clutch. I think it's good for something like 350 torque. More than my car will generate.
Old Feb 29, 2008 | 02:19 PM
kennyfrc1's Avatar
ACT Prolite and OEM clutch.
Old Feb 29, 2008 | 03:20 PM
jones75254's Avatar
https://www.rx8club.com/showthread.php?t=135070
+1
Give him a shout before u decide.
Old Feb 29, 2008 | 03:55 PM
staticlag's Avatar
The Professor
wait for the BHR one, its going to be the best thing available besides the $1000+ carbon setups.
Old Feb 29, 2008 | 11:10 PM
please search flywheels flywheels flywheels.. then after reading that this is a new and very good option..
https://www.rx8club.com/showpost.php...&postcount=469
Old Feb 29, 2008 | 11:12 PM
Easy_E1's Avatar
BHR has he sheet now!!!!
https://www.rx8club.com/showpost.php?...=&postcount=469
Old Mar 3, 2008 | 02:35 PM
05rx8mazda's Avatar
B.I.G
im running Sr motorsport 9lbs flywheel...
good thing is car revs MUCH quicker takes a littel getting used. youll find yourself over revving but youll eventually get used to it.
I have a 50 % strogner exedy clutch.. the entire things cost me 1000 dollars.
what also happens due to clutch.. is it occasionally stall while idling but not too often.. maybe once a month or once every two months it will stall.. also you will feel a vibration but its practically normal.. its a minot vibration but none the less you still feel it.. odd thing is someitme you feel it and sometimes you dont haha
but i reccomend it 100%
Old Mar 3, 2008 | 02:45 PM
mysql's Avatar
Doppelgänger
I bought the ACT Prolite flywheel and ACT HD Clutch. It cost me around $700 shipped and install was free.
You shouldn't be stalling at idle. But when you start moving because the clutch grabs harder and the flywheel doesn't have much momentum, it can be easier to stall initially.
By the second day I drive it like it was stock.
Old Mar 3, 2008 | 03:38 PM
staticlag's Avatar
The Professor
If your stalling at idle it means your neutral switch got screwed up.
Old Mar 3, 2008 | 03:40 PM
staticlag's Avatar
The Professor
well, prehaps many already know, but when I weighed the supposedly 8.5 lb fidanza it actually turned out to be 10.5 lbs, they must have weighed it without the friction surface or something.
So the true 8.5 lb wheel that BHR is offering is actually pretty huge.
Old Mar 3, 2008 | 06:17 PM
05rx8mazda's Avatar
B.I.G
its not that im stalling when im at idle. once in a while my rpms drop low and it just doesnt crank over it doesnt happen too often but its practically normal when you upgrade to a lighter flywheel.
Old Mar 3, 2008 | 06:23 PM
mysql's Avatar
Doppelgänger
it's not normal. You shouldn't stall at idle because of the flywheel. You're the first one to complain about this that I've read.
Old Mar 3, 2008 | 06:29 PM
staticlag's Avatar
The Professor
thats not normal
Old Mar 3, 2008 | 11:05 PM
ACT PROLITE and CENTERFORCE clutch.
Old Mar 4, 2008 | 02:16 PM
Jason's Avatar
RX7store.net
Just get an ACT clutch and flywheel. Anymore than that and your just throwing money away.
Old Mar 4, 2008 | 11:20 PM
MarauderWolf's Avatar
I would also strongly suggest checking out BHR, I am happy with my ACT prolite and Exedey Stage 1.
Old Mar 6, 2008 | 11:55 PM
Charles R. Hill's Avatar
Owner of BHR
Care to elaborate, Jason?
Old Mar 8, 2008 | 07:47 PM
05rx8mazda's Avatar
B.I.G
resetting the E-shaft profile??? whats that? how do i re set it?
the idle switch?? how could that have gotten damaged?
Well im not stalling all the time its once in a while. car hasnt stalled in over a month now. but i do get a vibration like a rattle once in a while. i googled it up and ive read taht lightetr flywheels can cause your car to stall due to it not having enough momentum to crank over. and it causes a minor vibration.
Look it up if you dont beleive me
go to google and type
flywheel causing car to stall
Old Mar 9, 2008 | 12:41 PM
Jason's Avatar
RX7store.net
Over the past 9 years of selling RX-7 parts I have seen people throw money down the drain on a regular basis. For the average RX-8 you dont need anything more than the ACT setup. Spec also makes some decent stuff. I have 400, 500 and 600HP RX-7's running ACT and Spec. I get a laugh when I see RX-8 owners saying they want double and triple plate setups for a car that makes 200-300HP. It was sort of the samething back in the day with RX-7's, but over time we have figured out whats a waste of money and what isnt.
Jason
Old Mar 9, 2008 | 01:16 PM
Owner of BHR
Thanks for the explanation, Jason. On that issue of getting "too much clutch" I totally agree with you. On the issue of throwing money down the drain many people think that's what the entire aftermarket industry is predicated on and we on this forum have had our own arguments about it, too. Look at how many people swap out the intakes and clutches as their first items when Mazda makes a really nice intake system and Exedy makes a really nice clutch that comes in the car, too.
I must admit I made the same error of judgement, myself, when I got the ACT Xtreme Duty pressure plate(which is rated for 443 lb./ft. of torque/600+ h.p.) so soon before my own clutch was even CLOSE to needing replacement. That's how I came across the problem of weak clutch pedal assemblies. I eventually swapped the factory set up back in and I will soon be using one of my own clutch systems when they are available.
The thing that makes the BHR clutch unique is that they are aluminum pressure plates so we can get the lightweight benefits of aluminum plates without having to spend $1,000+ to get it.
Old Mar 9, 2008 | 11:21 PM
the two above posts are about as accurate as have been mentioned in a while.. sometimes less is more.
RA32425
Series I Engine Tuning Forum
10
Sep 8, 2015 08:53 AM
iTs Ghastly
Aug 28, 2015 02:40 AM
Riot
Aug 27, 2015 04:01 PM
craig12895
Aug 25, 2015 04:50 PM
