are 8's just hard to start?
Old Feb 28, 2008 | 06:04 PM
JGR4444's Avatar
GR
this is my first ever experience with a rotary engine so i dont know to much about it and i have not had the car to long so i have only seen it in cold weather...
are the rx-8's just always hard to start or is it just the weather? because mine cranks for proabably a good 5-8 seconds before it kicks... is this unusual or should i have it looked at?
Old Feb 28, 2008 | 06:19 PM
mike73737's Avatar
Do you have an 04? Is it the original battery/starter? If so, then yes, have it looked at. I bought an optima yellow top and mine starts a little better, but still not as quick as some other cars. 5-8 seconds is too long though, mine takes 2-3.
Dive Bum's Avatar
IYAOYAS
Living in Florida, I do not know how the 8 would react to cold weather. Though the last couple of days here it has dipped down to the lower 30s in the AM. I have found that when I turn on the ignition, I'll hear (what I believe) is the fuel pump. I always wait until it finishes, then I move the ignition to the start position. The car usually starts after a couple of seconds in the start position. I just read through the owner's manual and it does not say weather or not this is correct, but I have not experienced any of the problems that you described.
Old Feb 28, 2008 | 06:22 PM
my 8 starts in usually less than 1 second. the most would be 2-3 seconds.
Old Feb 28, 2008 | 06:26 PM
Napboy's Avatar
Sho'Nuff
if you have any older model, there was a tsb on hard starts. i took my 04 in and told them i was having trouble starting it and they replaced the battery, plugs, and starter. now it starts really fast with much more gusto.
Old Feb 28, 2008 | 06:52 PM
CyberPitz's Avatar
Huge hole is huge
Same here, but the more than 1 second has only been once....and it dips down to the 20's usually here.
Old Feb 28, 2008 | 06:55 PM
New Yorker's Avatar
Hot or sub-freezing cold, mine always fires right up in a second or two. No exceptions. Just like an ordinary car.
Old Feb 28, 2008 | 07:00 PM
rglbegl's Avatar
Baned
12A with a carb, that is hard to start
The 8 is easy
Old Feb 28, 2008 | 08:04 PM
04RX8man's Avatar
Rotary Powered Countryboy
IDK if I would say "hard" to start yeah when it's cold it does take a little longer to start up I am not driving mine this winter but last winter if it was below 20 it took awhile but usually 2-3 4 seconds at max......I think u r ok but if it is an 04 have it looked at.....
Old Feb 28, 2008 | 08:56 PM
Take it to the dealer and complain. Print out the TSB. Tell them you want the new starter.
Old Feb 28, 2008 | 09:12 PM
mike73737's Avatar
How can you tell if you have the updated starter or not? I've asked for it and they blamed slow starts on "bad gas" (the car's, not mine). If I don't have it I'd like to get it before the warranty is out.
Edit: From the TSB by the way:
Is the VIN at or below JM1FE173*** ** 150745?
- NO – Starter replacement is not necessary, go to STEP 11 in REPAIR PROCEDURE “A”.
- YES – Go to STEP 2.
So if your VIN is higher than 150745 you've already got the updated starter from the factory.
Old Feb 29, 2008 | 12:15 PM
Design1stCode2nd's Avatar
I have an 06 and it always starts up in the cold but you can tell it doesn't like it.
Old Feb 29, 2008 | 12:25 PM
JRichter's Avatar
Void Where Prohibited
Mine, on occasions, will take 3-4 seconds at the most but always starts just when the fear of it not starting begins to set in.
Old Feb 29, 2008 | 12:39 PM
8 Maniac's Avatar
Senior Member
same here, it usually starts in like 2 seconds, maybe 3.... but then there's sometimes where I'll end up holding it there for about 5-7 seconds maybe and it doesnt sound like it wants to, but it's trying... finally does.
Would the fact I have the RB intake + nitrous get in the way of the TSB? it's a tight fit for the blue tube + the billow with the nozzle there. If that does have to be moved for the TSB then I'll wait till the BHR spacer is out and take it in after that.
Old Feb 29, 2008 | 12:42 PM
sauceyI986's Avatar
just think if you had a lamborghini some of those take 4 secs to start
poppinparker
Aug 10, 2015 09:20 AM
harithac
Jul 25, 2015 04:21 PM
dbarber
Jul 25, 2015 01:34 PM
dmac1961
Jul 24, 2015 11:27 AM
