West RX-8 Forum Serving CA, NV, AZ, HI
SoCal Lounge
Old May 15, 2009 | 12:09 PM
  #2851
dozer's Avatar
on his 3rd rx8
atilla where are you gonna be doing it at?
Old May 15, 2009 | 12:12 PM
  #2852
shadycrew31's Avatar
WENTGERMAN
Originally Posted by blamerobb
oh there was someone selling one at the meet. its a straight pipe and i wanted to weld a resonater on it as well. as for the second o2 hole...well idk what that would do?
2nd hole is for a wide band..
I'll sell you my mid pipe for $100 already has a resonator and its all brand new.
you just need a gasket I hear turbo xs sells em for cheap and you need to cut the flange holes.
I just don't want to go through the hassle.
I've taken off my mid pipe 4 times already and I'm not taking it off again until I have a mid pipe with longer resonator or maybe a hi flow and a 2nd 02 bung.
Old May 15, 2009 | 12:17 PM
  #2853
dozer's Avatar
on his 3rd rx8
the gaskets are easy to make...i have a custom one on right now ...and i got the original gasket from turboxs at home
Old May 15, 2009 | 12:20 PM
  #2854
Atilla's Avatar
I am THAT guy
Dozer: is it cool if I stop by your place and do it all there?
Old May 15, 2009 | 12:21 PM
  #2855
dozer's Avatar
on his 3rd rx8
ahahahhahahahahha no.....
i mean no, wait, NO again! ahahahahhaha just kidding why do you even ask?
Old May 15, 2009 | 12:24 PM
  #2856
blamerobb's Avatar
hmmm i want a midpipe. cant u just use that gasket maker. the adhesive stuff. and i was gunna ask you guys if u wanted to do my suspension sat? switch springs and install sway and links.
y dose the flange need to be cut? Dozer what do you think i should do??
Old May 15, 2009 | 12:26 PM
  #2857
dozer's Avatar
on his 3rd rx8
robb does your exhaust mate up to the stock cat perfectly?
Old May 15, 2009 | 12:29 PM
  #2858
blamerobb's Avatar
yes sir. it was butter installing it
Old May 15, 2009 | 12:31 PM
  #2859
dozer's Avatar
on his 3rd rx8
if you get it, you wont have to cut anyting, it SHOULD bolt right up, but you will need a gasket
Old May 15, 2009 | 12:32 PM
  #2860
blamerobb's Avatar
can i use gasket maker? i have some in my trunk and used it on my muffler to connecting pipe. it worked fine
  #2861
nikkdizzle's Avatar
Daddy's Home...
wish i could say the same about installing mine.
Old May 15, 2009 | 12:39 PM
  #2862
WENTGERMAN
any other mid pipe but the turbo xs bolts up...
but yea if your getting a RB mid pipe or whatever you dont need to cut anything bolts up just fine.
  #2863
dozer's Avatar
on his 3rd rx8
hnmmm i dont see why not, if you say its good then yeah, ive never used that stuff, i just went to autozone and bought a 5 dollar gasket and customized it
  #2864
WENTGERMAN
did you ever get yours figured out?
Old May 15, 2009 | 12:41 PM
  #2865
dozer's Avatar
on his 3rd rx8
shady, my midpipe is using the actual holes in the flange, im not use the "custom" holes the previous owner had...my turboxs is bolted right up the stock exhaust, if his RB exhaust is bolted up the stock cat, then the holes are the same and should bolt right up
Old May 15, 2009 | 12:44 PM
  #2866
blamerobb's Avatar
wait im confused why wouldnt it bolt right up and what are you talking about cutting the flanges
nick i wish yours went easier too. hahah
Old May 15, 2009 | 12:45 PM
  #2867
nikkdizzle's Avatar
Daddy's Home...
yeah got in on and it sounds amazing, i'm never gonna put the stock one back on!
however, when me and blamerobb were installing it, we couldnt get the spring loaded bolts back on, they were serioulsy like 1mm short and the thread wouldnt catch..
is it bad if i just have regular bolts holding connecting it to the cat pip?
  #2868
dozer's Avatar
on his 3rd rx8
shady has the HKS hi-flow, the turboxs doesnt mate up perfectly unless you cut it
Old May 15, 2009 | 12:46 PM
  #2869
Roariee's Avatar
It was this big! No lie!
Yes, the springs are there for a reason. You need to allow for flexing...
Reinstall and have a friend push the exhaust while you attach the midpipe...
Disconnect the midpipe from the header so you get some wiggle room...
Old May 15, 2009 | 12:48 PM
  #2870
WENTGERMAN
All I know is I put mine in and the holes were off by 1/4 inch on either side. and the hks lines up perfectly with the stock cat. so whoever gets mine needs to cut the flange or get it cut and re-welded at a shop.
Old May 15, 2009 | 12:49 PM
  #2871
blamerobb's Avatar
oh ic ic. so which do u think would sound better dozer rx7 store or this one? this is resonated right? and the reverand says i can try his out for a couple days to see how i like it....
Old May 15, 2009 | 12:50 PM
  #2872
WENTGERMAN
Originally Posted by roariee
yes, the springs are there for a reason. You need to allow for flexing...
^+1
  #2873
blamerobb's Avatar
thats retarded y would they sell something that has a crappy fitment??
  #2874
nikkdizzle's Avatar
Daddy's Home...
hmmm, dang. ok i'll need to do that then.
dozer your place saturday?
Old May 15, 2009 | 12:53 PM
  #2875
WENTGERMAN
no one really knows..
but to compensate for the stupidity they made the flange on the cat back side able to spin so it lines up alright. So if you have a turbo xs cat back system your flange moves and that's why.
