allosaur
02-26-2008, 03:05 PM
My right tail light has lots of condensation in it. Also, I just took it to the car wash and it seems to have filled up a bit with water. I've noticed this problem in some other RX-8s I've seen on the road. Is this a manufacturer defect? Suggestions? I'm pretty much a noob when it comes to cars. Thanks.
987HYS
02-26-2008, 03:20 PM
If your car is still under warranty, the dealership will fix it. its a common problem, and its a bad gasket in the housing that needs replacing. search for more info
laythor
02-26-2008, 03:21 PM
it's a common problem on older 8's
search and you'll find the TSB about it
dealer should replace them for you
XLR83N
take it to mazda under warranty, if not, umm take the light out and try to find the leak and seal it some how or just buy a new tail light
Minotavr
04-30-2008, 07:01 AM
Replace the gasket ! It's by far the worst thing in an RX-8 !
expo1
04-30-2008, 07:11 AM
If you warranty is still valid go there while the condensation is still there. If the dealer doesn't see it they might not order you a new one.
crimson-rain
04-30-2008, 07:28 AM
minotavr, is it possible to order a new gasket for the tailight? I'm on my 2nd tail light and I'm out of warranty period.
Minotavr
04-30-2008, 09:01 AM
Of course it is, unfortunately I can't give you the code# for the gasket. But any dealer should know that.
midlifer
04-30-2008, 09:54 AM
If your 8 is not under warranty then you can buy the gasket and do it yourself.
http://www.finishlineperformance.com/store/product.php?productid=16881&cat=302&page=1
Bob
m3pkrobert
04-30-2008, 10:17 AM
drill a small hole in the bottom and it will b fix
crimson-rain
04-30-2008, 07:11 PM
http://www.finishlineperformance.com...cat=302&page=1
Bob
sweet. and I live relatively close by (I get my 8 serviced there and everyone there in the service department is AWESOME).
My tail light did the same thing. I bought the Mazda gasket, which is stupid expensive, It is just a bit thicker than the original which is just a piece of foam of some sort .Most likely the water is running in at the top of the tail light right below where the water drains off the trunk lid. There is good info on how to remove the tail light right here on the forum. Take it out , dry the water out . I used compressed air, but there are other ways. Get you some clear silicone sealer and put a small bead of the silicone on the rear panel where the gasket contacts the panel.Put your tail light back in and no more water. Hope this helps .
05rex8
04-30-2008, 07:54 PM
+1 did this and no issues
nuke0907
04-30-2008, 08:06 PM
.....so far.
just get the gasket from finishline. the hole might seem to help but it does not fix the problem which is the gasket.
